Go to Post There is almost always more than one solution to any engineering problem. One part of elegant design is picking the one that makes the most sense for a particular design problem, even if that means "breaking" some normally established "rules". - Jeff Pahl [more]
Unread 16-02-2011, 16:52
dbeckwith's Avatar
dbeckwith dbeckwith is offline
Lead Programmer
AKA: Daniel Beckwith
FRC #3205 (The Patriots)
dbeckwith is an unknown quantity at this point
powering two cameras
We want to use two cameras at once. They will be plugged into the D-Link by ethernet, but to power them, they both need 5V. The only 5V is one port on the PDB. Is it legal to split two cables form this? If not, how else can we power two cameras at once?
q = (2*b) | ~(2*b);
if (life.getLemons() != null) this.lemonade = new Drink(life.getLemons());
else throw new NoLemonsException("What now?");
Unread 16-02-2011, 23:33
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Team Role: Coach
Dale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud of
Re: powering two cameras
We have three cameras being powered by the 5V output of the Power Distribution Board. It works fine and we could find no rule against it. The 5V output is rated at 3A. Our three cameras are less than half that.
2016 PNW Championship Chairman's; 2016 Winner Oregon City District, 2015 PNW Championship Chairman's; 2015 PNW District Engineering Inspiration; 2015 PNW District Finalist; 2014 PNW Championship Chairman's; 2014 Championship Innovation in Controls; 2013 Chairman's (Oregon); 2013 Finalist (OKC); 2012 Winner (OKC); 2012 Chairman's (OKC); 2012 Woody Flowers (Oregon); 2011 Volunteer of the Year (Oregon); 2011 Finalist & Captain (San Diego); 2011 Innovation in Control (San Diego); 2010 & 2007 Chairman's (Oregon); 2010 Regional Champions (Colorado); 2010 Innovation in Control (Colorado); 2009 & 2008 Engineering Inspiration (Oregon); 2008 Regional Champions (Oregon); 2007 Regional Finalist (Oregon); 2005 Rookie Inspiration (PNW)
Unread 17-02-2011, 08:00
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Guys,
Check the Q&A, I remember seeing a question about multiple cameras but i don't remember the answer.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 17-02-2011, 09:55
ptitchener ptitchener is offline
FRC #3205
ptitchener is an unknown quantity at this point
Yes, there is something on Q&A about this (http://forums.usfirst.org/showthread...hlight=camera). The problem is is that they do not actually answer the question about how the second camera should be powered, they just say that that is something that a team needs to figure out on their own. Do you think that they would answer the question if it was more specific, such as asking if the second camera could be powered from the same port as the first camera, or if they would answer the same way?
Unread 17-02-2011, 10:55
Unsung FIRST Hero
Rookie Year: 1996
They might answer a question like "Can we power more than one camera from the PD dedicated camera power supply if all other electrical rules are followed?"
I cannot see any rules that prohibits two cameras electrically. However R38.D & R40 are two rules I would check. Also, does not the +5 volt supply on the breakout or DSC also power the camera?
Al
WB9UVJ
www.wildstang.org
Unread 17-02-2011, 11:06
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
We've powered the camera from the DSC before. The old (red) analog breakout could probably do it also. The new (blue) analog breakout is only rated for 0.25 amps, so that would probably not be a good idea.
Unread 17-02-2011, 11:11
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
I don't see anything specifically mentioning the 5 volt output on the Power Distribution board. This is definitely something that should go through the official &A.
Powering 5v cameras from the Digital Sidecar should work, and it looks to me like doing it that way would follow the electrical rules.
Unread 18-02-2011, 09:26
Peyton's Avatar
Peyton Peyton is offline
Electrical Captain 1591
FRC #1591 (Greece Gladiators)
Team Role: Electrical
Rookie Year: 2010
Peyton is an unknown quantity at this point
In my teams KoP we got a dc(24V) to dc(5V) converter which is what i am using to wire up the camera this year.... Just a suggestion
Unread 18-02-2011, 09:29
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We got a 12v to 5v converter, but we're using it to power the Dlink wifi bridge, as required by the rules.
