Go to Post Failure is not an option. - [more]
Unread 16-02-2011, 17:18
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Team Role: Coach
Rookie Year: 2010
Robby Unruh will become famous soon enough
Robot Arm Victor Motor
Our team's mechanical engineer insist's our arm not working is a program error. I don't think so, so I just want to double check here.
Code:
Victor arm;
public void robotMain() {
    arm = new Victor(10);
public void operatorControl() {
    while(isOperatorControl()) {
        getWatchdog().setEnabled(true);
        getWatchdog().feed();
        if(joy.getRawButton(10)) {
            arm.set(-0.2); // arm goes down.
        } else if(joy.getRawButton(11)) {
            arm.set(0.2); // arm goes up.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 16-02-2011, 17:24
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Robot Arm Victor Motor
Can you describe what the problem with the arm is? Just looking at the code, once the arm starts moving, the arm will always be moving in one direction or the other, which might not be desirable.
Unread 16-02-2011, 17:30
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Rookie Year: 2007
Robototes2412 is on a distinguished road
Code:
        } else {
            arm.set(0);
Did you check the pwm?
Code:
class team2412(GP):
    def __init__(self):
        GP.__init__(self)
        self.coopertition = True
        self.info = {"name": "Robototes", "school": "Sammamish High School, Bellevue, WA"}
        assert self.kind_people == True
Unread 16-02-2011, 18:05
Team Role: Coach
Rookie Year: 2010
Sorry, I mean the arm doesn't move at all.
It is plugged in to channel 10.
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
Unread 16-02-2011, 19:24
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Can you show us where you initialize arm? That may be the problem.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 16-02-2011, 19:55
Team Role: Coach
Rookie Year: 2010
All arm-related code is given above. It is initalized in the robotMain function.
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
Unread 16-02-2011, 20:06
Rookie Year: 1997
Here's a number of non-code related things that could cause a motor not to move:
You didn't enable the robot on the driver station
You didn't plug the PWM cables from the victor to the digital sidecar PWM ports
The PWM cable missed the connector inside the shroud on the victor (this is very easy to do).
You didn't power the digital sidecar
The digital sidecar isn't plugged into the digital module in slot 4 of the cRIO
You have the PWM cables plugged in backwards. B is for black wire.
You have the PWM cables plugged into the wrong PWM ports on the digital sidecar.
The circuit breaker is immediately tripping.
The speed controller isn't powered.
The motor isn't connected to the speed controller.
Knowing what the LED is doing on the speed controller would help narrow down the problem
Unread 17-02-2011, 08:49
Team Role: Coach
Rookie Year: 2010
We covered the majority of those grounds last night. We plan on re-checking today after school.
However, the motor is getting power, and is blinking orange.
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
Unread 17-02-2011, 08:56
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Are you sure you are pushing "Button 10 and Button 11"?
For laughs and tickles try using the joystick value to eliminate any posability that it is the mechanical/elecrtical problems.
x2 on checking the connection of the pwm cable.
I hated redoing pwm cables on the victors they always seem to not go into the header when you need it to!
Unread 17-02-2011, 09:01
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Blinking orange on the Victor suggests a problem with the PWM cable connection (or you never initialized "arm").
Unread 17-02-2011, 09:14
Team Role: Coach
Rookie Year: 2010
In the actual code we had only done:
Code:
Victor arm = new Victor(10);
outside of robotMain. Could that actually be the problem? I never thought it mattered.
[Robots R Us #3266]
2011: Buckeye
2010: Buckeye
Unread 17-02-2011, 13:26
Originally Posted by Robby Unruh View Post
...and is blinking orange.
To me, this remains the most conspicuous clue. A blinking orange speed controller is one that does not have a working connection to a properly configured PWM port on the digital sidecar. Be absolutely, positively sure your PWM connector is fully seated at both ends.
