Re: Arm goes down too fast?
http://www.youtube.com/watch?v=a_yD4oc4j2g
two window motors driving a 22 or 24 tooth sprocket (forget which one) with chain to a 60 tooth sprocket with the arm bolted directly to the sprocket. on the back of the arm is the bungee cord running down the back. This test was from a few days ago so it still shows it slamming down into the frame (why the mentor is holding on to it, to keep it from doing that) Both window motors are being drivin from victors in brake mode (Had jags, but they locked up) Let me know if you need any more info Quote:
I suggest a weighted counterbalance for the backside of the arm (meaning you would have to add an extension to your current arm) like industrial cranes have. you have a great deal of leverage and weight on your business end and you need to be able to have the arm naturally balance horizontally on its own, or close to it.
Your arm seems pretty rickety, especially for the weight it is trying to support. Forgive the paint-CAD, but you can add a lot of rigidity to a thin arm with some supports and steel cable, while adding almost negligible weight.
(Also, I agree with the neutral balance suggestions. We're using a four-start screw and a FP motor on a 64:1 BB for our lift, and we can stop it anywhere we want and it just stays there... It helps that we can lift the arm from behind the pivot with one finger!) |
The only problem is that I can't really think of a way to do it, we only have about a half inch from the top of the sprocket to the height limit, and the same with to the back of the robot |
What size aluminum is the arm made of?
the arm is bouncy just because of the thickness of that piece mainly. Also, I am worried that some other robot will run into your arm, and when that happens, my bet is that you will need to remake your arm. suggestions: It is late in the build season and im not sure how much manufacturing ability you have. Replace the ARM piece with a piece of 1.5" by 1.5" aluminum square. with 1/8" wall thickness. balance the arm so without the motor it can stay in the middle position on it's own. use a more powerful motor such as a cim or 775 motors. gear ratio need to be around 800 to 1 for 775 and about 200 to 1 for the cim. bring the bearing holding your main arm shaft as close to each other as possible. |
Robustness will certainly be an issue. Make spare parts. Lots of them! (...but less than 30 lbs of them...)
Compromise is the key word. ![]() |
