Re: Problem with LabView Update 3.2 #2
We had to remove some code that was measuring a Potentiometer in a while loop inside the teleop.vi The code wasn't running fast enough for the WPI_RobotDriveSafetyUpdate.vi to get the update signal that resets it so it disables all PWM signals. Then the Jag's/Victors see no control and disable their oututs. I think...
Can you post your code? In general, it is a bad practice to put while loops in the Teleop.vi for the reason you mentioned. When we implement sensors we normally put these in a "Sensors" While Loop in Periodic Tasks, with about a 20-40 ms wait.
We extracted it out of the zip file and then ran the application. After re-imaging the cRio it should work. The update came out yesterday.
When the v28 cRIO image came out, we re-imaged our cRIO, and confirmed through the Driver Station. At the time (and currently) our classmate is at LV Update 3.1 The recent Update #12 says that Labview Update 3.2 and cRIO v28 firmware are required. We will be updating our classmate to LV 3.2.
Is there any reason for us to re-image the cRIO with the v28 image that comes with LV 3.2? I do not believe there would be, since I'm sure that the v28 images are the same. I just want to make sure, can one of the NI reps answer this? |
I don't know what the NI reps will say, but I know when we don't install ALL updates and reimage, things don't go right. Also if the little version number is wrong when the inspectors look at your robot, you'll have to fix it at the regional. We reimaged ours yesterday, it works, it might pass inspection.
squirrel - Thanks for the response. To clarify, we will have everything updated (the DS and the cRIO) to the most current version at our event. My question is if it will be necessery to re-update the cRIO to v28 after we update the DS to LV 3.2, because the cRIO is already at v28 and the DS is at LV 3.1
Last edited by DavidGitz : 22-02-2011 at 14:04. Reason: put clarification text in separate post |
what I was hinting at is, when in doubt, reimage. it's not worth the hassle of having to do it later if you can do it now.
The reason that I'm posting this is because we have already shipped our robot, and trying to avoid any un-needed downtime on our first day at our event. I understand that re-imaging the cRIO is not normally a time consuming process, but sometimes things happen, and I would rather avoid having things happen at an event that do not necessarily* have to happen. It's all about proper risk management. Normally, I would absolutely agree with your comment about "worth the hassle". However, there have been (very rarely) times when re-formatting the cRIO for whatever reason, including a firmware update, resulted in a series of events to happen that resulted in a significant increase in down-time. Some of these reasons include: Ethernet connection comes unplugged, battery dies, computer stops responding, etc. Obviously most of these things can (and are) mitigated as best as possible by proper procedures, communication and extreme diligence. But sometimes things happen, that you cannot control.
Necessarily is obviously the word in question, and since I was not involved with developing the changes and the documentation supplied does not imply that updating the cRIO before the Driver Station is required (as long as the cRIO is at the correct level before-hand) I feel this is a valid question. |
I'm still not sure if I know what you're asking. Are you asking if the v28 image from Labview update 3.2 installed from your own computer is the same as the v28 image from LabVIEW update 3.2 installed from the classmate? Or, did you download the pre-release v28 image that Joe Hershberger posted, and want to know if that is the same image that was installed the the LabVIEW update 3.2? Or something else?
