Go to Post Maybe FIRST could get a sponsorship from Ikea, and we all could get flat-packed field parts with pictoral assembly instructions. And then all the parts could have funny names. - sanddrag [more]
Unread 17-02-2011, 07:55
martin417's Avatar
martin417 martin417 is offline
Opinionated old goat
AKA: Martin Wilson
martin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond repute
Will this year's game be a war of attrition?
As I look at posted robot pictures, I begin to worry about robot longevity this year. The parts provided in the KOP, if used as-is, will produce a ~16 FPS robot. I see that most teams are gearing for around that same speed, either using shifting transmissions or the KOP parts. In the past, kit-bots, and most non kit bots have been geared for between 9 and 12 fps. In other words the robots will be very fast this year.
Defense near the home zone will be dangerous due to team update #6, so expect VIGOROUS defense around midfield.
Team update #9 adds:
High speed accidental collisions may occur during the MATCH and are an expected part of LOGO MOTION™. ROBOTS place mechanisms outside of the BUMPER PERIMETER at their own risk; no penalties will be assigned for contact between two such extended mechanisms.
Most of the robot pictures I have seen posted show mechanisms outside the frame perimeter. By the end of any given regional, I would not be surprised to see a significant proportion of those robots with no usable manipulator.
Team updtae #9 also added:
A ROBOT with a mechanism outside of its BUMPER PERIMETER may be penalized under this rule if it appears they are using that MECHANISM to purposefully contact another ROBOT inside its FRAME PERIMETER. Regardless of intent, a ROBOT with a MECHANISM outside its BUMPER PERIMETER that causes damage to another ROBOT inside of its FRAME PERIMETER will be penalized.
Repeated or egregious violations of this rule will earn the offending ROBOT a YELLOW CARD.
This is one of the reasons our team probably will not attempt to pick up a tube from the floor. As it now stands, no part of our robot ever extends outside the frame perimeter. (except during end-game)
In the finals, it may turn out that the last robot still working is the winner.
I'm not Car Nack, but I am hereby predicting mayhem.
Former Mentor Team 1771
Former mentor Team 4509
Unread 17-02-2011, 08:01
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Re: Will this year's game be a war of attrition?
If the robot weighs 120lbs, even with 4 CIMs it likely won't have nearly enough room to accelerate to anything approaching that speed.
Unread 17-02-2011, 08:04
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Team Role: Mechanical
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
This is another good reason to have a detachable manipulator and a spare. It won't help you for the match it gets broken, but hopefully you will be in better shape for the next match.
Unread 17-02-2011, 08:17
MaxMax161's Avatar
MaxMax161 MaxMax161 is offline
Allegedly Useful
AKA: Max Llewellyn
FRC #2791 (Shaker Robotics), FRC #1676 (Pascack π-oneers)
MaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond repute
We know our manipulator is going to get the s!@# kicked out of it so I think we are using some of our 30 lbs with 4 extra. I know as soon as the doors open our manipulator people will get to building as many extra as they can.
2791 Shaker Robotics (2013-present)
--Control Systems Mentor 2013-present
--Drive coach 2015-present
1676 The Pascack π-oneers (2010-2013)
--Drive coach 2011-2013
--Lead Programmer 2011-2013
Unread 17-02-2011, 08:20
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Rookie Year: 2007
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
teams aquire this speed relatively easily and quickly, we did this with the additional weight of the bumpers and minibot. we did this speed with a 150 lb robot in like week 2 in less than 20 feet...
Unread 17-02-2011, 08:22
AndyH's Avatar
AndyH AndyH is offline
FRC #1098 (Rockwood Robotics)
AndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud of
Thanks this is interesting.
The reasons you lay out here is why our students designed a tube pickup tool that when the robot travels the tube is inside the bumper zone. May help keep the bot together. That and my annoying speeches about make it TOUGH.
Tough is something that the team has started focusing on in the last few years, because mentor Andy won't shut-up about it.
Unread 17-02-2011, 08:32
martin417's Avatar
AKA: Martin Wilson
The field is ~50 feet long. With a two-speed transmission, coming from the feeder station with a full head of steam, I expect a well made robot to be approaching that speed by midfield. One strategy to avoid defense is speed. if a robot comes screaming out of its lane, heading towards the home zone at ~16 FPS, any robot that gets in the way does so at its own peril. And don't assume 120 LB.s The robot weighs in at 120, the battery 10, the bumpers another 20, and up to 15 for the minibot gives a max weight of 165 Lb. or 75 Kg. At 15 FPS (4.6 M/s), you will have 616 ft-lb (835 N-M) of energy, all dissipated in milliseconds. Even if you don't have anything outside your frame perimeter, that is a lot of energy to absorb without damage.
Unread 17-02-2011, 08:52
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Absolutely, robots with shifters can certainly reach 15-16 FPS. My point was that the KOP bot will not if it weighs anywhere near 120 without battery bumpers and minibot.
If I did the math right the KOP setup (at 148lbs total) will take over 100 ft. to accelerate to top speed. Adding an additional pair of CIMs still puts it at over 60ft. to reach its top speed.
Unread 17-02-2011, 09:14
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Rookie Year: 1999
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
"Back in the day, we didn't have those weenie bumpers!"
Unread 17-02-2011, 09:21
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Yea.... When Robots were Robots. Metal against Metal. Puts a big smile on my face also
Blue Shirt Alaska Pics here and Amsterdam pics are here!!! and Puffin Pics
Unread 17-02-2011, 09:22
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Regarding picking up from the floor:
Maybe in midfield it's a risky proposition, but picking up tubes in your scoring zone or human player lanes seems like a no brainer to me. You're protected from being touched in those areas.
-Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 17-02-2011, 09:23
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
There will be some big hits, that's for sure. We will be bringing many spare manipulators to competition for this reason. We will also be devoting a large share of time this week and with our practice bot to train the operator to get the manipulator out of the way as quickly as possible.
Unread 17-02-2011, 09:27
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
For those robots with a long arm, I wonder how it will work driving around with the arm sticking almost straight up? There's the fun thing about the CG being relatively high, and the robot wanting to fall over during sudden maneuvers...and you have to watch out for minibot towers...and other robots with stuff sticking out up high. Especially if you're possessing a game piece.
I'm thinking our decision to use mostly all locally available materials, and a few bolts and rivets to hold it all together, might be a good decision.
Unread 17-02-2011, 09:29
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
This is an interesting question.
Logo-motion is the First game since 2008 where Teams are pretty much allowed to expand beyond the bumper zone without restrictions other than a maximum expansion Distance. I would venture to say that the majority of teams are compromised of students that only have experience with 2009 and on (those who don't would've had to have been Freshmen in HS in 2008) and then there are hundreds of teams that have been born since 2008. It'll be interesting to see how well these teams build robots and if they understand the abuse that a mechanism will take if it leaves the bumper zone.
Well-Structured and mentored Veteran teams, I'm sure, will have few issues with machine robustness as many of them existed in the "Pre-Bumper Era" and should remember how to build a robot to take abuse. Personally, 816's robot was designed in such a way that all mechanisms that leave the bumper zone are protected while not in the safe zones, and the few other Veteran Machines I've seen thus far seem to be built with the same idea in mind.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
  #15   Spotlight this post!
Unread 17-02-2011, 09:41
martin417's Avatar
AKA: Martin Wilson
I did a quick spreadsheet to estimate (and making some known erroneous assumptions, but close) I estimate that a kitbot with roughtop wheels at 150 lb.s can hit 15 FPS in less than 20 ft, and about 1/2 second.
