Go to Post Once you try hex you'll never go back. - IndySam [more]
Unread 17-02-2011, 13:40
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Exclamation Driver Station Errors
Watchdog Expiration: System 1, User 0
ERROR <Code> -44061 occurred at "Left and Right Motors" in the VI path: Robot Main.vi
<time>19:42:17 02/17/2011
FRC: The loop that contains RobotDrive is not running fast enough. This error can occur if the loop contains too much code, or if one or more other loops are starving the RobotDrive loop.
<time>19:41:51 02/17/2011
ERROR <Code> -44003 occurred at WPI_CameraIssue HTTP Request with Authentication.vi>>WPI_CameraIssue Get.vi>>WPI_CameraSet Image Appearance Property.vi>>WPI_CameraSet Enum Appearance Property.vi>>WPI_CameraSet Image Size.vi>>Begin.vi>>Robot Main.vi
FRC: Operation failed due to a communication failure with the camera.
Watchdog Expiration: System 10, User 2
<time>09:56:40 02/17/2011
<time>09:56:34 02/17/2011
ERROR <Code> -44027 occurred at WPI_DigitalModuleDIOCache.vi>>WPI_DigitalModuleDIO Allocator.vi>>WPI_DigitalInputOpen.vi>>Begin.vi>>R obot Main.vi
<time>09:56:32 02/17/2011
FRC: The DIO channel has already been allocated.
<time>09:53:12 02/17/2011
I am getting these kinds of errors when I enable on my driver station!
I would be very grateful if anyone can help me!!!
Unread 17-02-2011, 14:02
FRC #2905
Re: Driver Station Errors
I also get these errrors:
<time>23:40:15 02/16/2011
No Change to Network Configuration: <noNICConfig><noNICConfig>
I/O unit not detected or not installed correctly.
Unread 17-02-2011, 14:05
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Don't worry about this one unless you get a lot of them. One is normal for changing robot modes: Disabled, Teleop, Autonomous
ERROR <Code> -44061
This means your Teleop loop might be running too slowly.
It means you aren't calling Arcade or Tank Drive quickly enough.
ERROR <Code> -44003
Is if the camera is not connected or if it's still booting when the cRIO tries to talk to it.
ERROR <Code> -44027
Means you used one of the DIO's twice.
Probably just left one of your Opens with the default DIO 1 and it conflicted with something else you Opened using that same DIO.
Unread 17-02-2011, 14:06
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
Team Role: Coach
Rookie Year: 1996
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
I believe these are common, we recieve these and received them last year and didn't have a problem.
Your Camera is timing out. If you are not using the camera, make sure the Enable Vision control is False (if using LV, don't about the other IDE's). If you are using the Camera, is the indicator ring on the front of the Camera green?
In your Begin.vi, check to make sure you are not opening 2 references with the same Digital Input
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
This means that you have assigned the same channel to multiple DIO's , this could be causing the loop to slow down and cause it to time out.
Unread 17-02-2011, 14:20
FRC #2905
Here is my Digital Input part of the Begin.vi!
Uploaded with ImageShack.us
But I dont think I have assigned same channels to two or more than two DIO s!
Unread 17-02-2011, 14:35
FRC #2905
Exclamation Re: Driver Station Errors
Actually I am getting lots of those errors!
Watchdog Expiration: System 8, User 0
Watchdog Expiration: System 7, User 0
Watchdog Expiration: System 6, User 0
Watchdog Expiration: System 5, User 0
Watchdog Expiration: System 4, User 0
This is just the one fourth of the errors I am getting!!!
Unread 17-02-2011, 14:41
Flywheel Police
Check to make sure that you have initialized all of the DIOs that you are using. We found out recently that if you forget to initialize something in the Begin.vi it will try to use the default values for it. This could be trying to create a default one on your Slot 4 DIO 1 channel. Also while it is trying to figure out the default it will cause a delay that triggers the watchdog problems.
Unread 17-02-2011, 14:47
Just Itinerant
That usually means the communication between the laptop and robot is flakey. It's slowed way down.
I saw this on one team still using last year's Classmate setup (with updated 2011 Driver Station).
The Classmate turned out to be "stuttering." They had too much going on on their laptop and it couldn't keep up with the robot.
That can be double checked by trying a different laptop running the Driver Station application.
It can also occur due to a weak or subpar wireless connection.
Does it still give these errors when you connect your laptop directly to the DLink on the robot via Ethernet cable?
I can't see images from Imageshack, so I can't give advice there.
Unread 17-02-2011, 14:58
FRC #2905
I am getting some other error after I deploy the code:
LabVIEW: Failed to load shared library FRC_UserProgram.out on RT target device.
Deployment completed with errors
Unread 17-02-2011, 18:26
Exernie Exernie is offline
FRC #3080
Exernie is an unknown quantity at this point
i also get this multiple times. how do we fix it.
Unread 17-02-2011, 21:06
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
With regards to the camera call, you can either not open it in begin or plug your camera in so it runs. It's timing out because it expects the camera to talk on the ethernet port and it isn't.
With regards to the other problems (loop running slow) we nailed this one tonight after a lot of work. What clued us in to our errors was that it was still happening even when the robot is disabled. We checked the VI's that were running in disabled and found references to things that we had removed from begin. We also found a duplicated reference in begin. After fixing those our 'loop too slow' disappeared.
Unread 17-02-2011, 21:12
FRC #3080
how do you find the errors and know what to delete.
Unread 17-02-2011, 21:22
On the driver station, click on the Diagnostics tab. The list will have error information that other posts are referring to.
Greg McKaskle
  #15   Spotlight this post!
Unread 18-02-2011, 08:18
FRC #2905
<time>09:00:09 02/18/2011
This is the error I am getting and I couldnt manage to solve it!
Here is my Teleop.vi
