Go to Post Welcome to CD! You'll find this is basically the coolest place on the internet. - Donut [more]
Unread 17-02-2011, 18:01
Samk Samk is offline
Lead Builder
FRC #0619
Team Role: Mechanical
Rookie Year: 2010
Samk will become famous soon enough
Window Motor Modification
Does anyone know if it is legal to modify the window motor gear box?
Unread 17-02-2011, 18:19
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Window Motor Modification
<R47> Motors and servos used on the ROBOT shall not be modified in any way, except as follows:
A. The mounting brackets and/or output shaft/interface of the motors may be modified to
facilitate the physical connection of the motor to the ROBOT and actuated part. B. The electrical input leads on the motors may be trimmed to length as necessary.
C. The locking pins on the window motors may be removed.
D. TheconnectorhousingsontheWindowmotors(PN262100-3030and262100-3040)may be modified to facilitate lead connections.
I believe the gear boxes on the window motors are considered integral to the motors and cannot be modified except as specified above. But I am not the GDC, so take that with a grain of salt and ask the only people who can help you... the official Q&A.
Unread 17-02-2011, 21:49
Lead Builder
FRC #0619
Rookie Year: 2010
Thanks! I did ask the Q&A but I wanted to see if anyone here happened to ask, under a weird title.
Unread 17-02-2011, 22:50
Speeder Speeder is offline
AKA: Mr. Don
FRC #0316 (LuNaTeCs)
Speeder will become famous soon enough
We checked about swapping the motors.
http://forums.usfirst.org/showthread.php?t=17068
Don
Unread 11-05-2011, 09:57
Lead Builder
FRC #0619
Rookie Year: 2010
Don
Thanks! But we ended up not needing to. And the thank you is a bit late, haha.
