Go to Post FIRST is kind of like charity work... you are, even if only in some small way, helping our future just a little bit, and you get a great feeling from it. Even if you are just ringing a bell (or clapping MOE sticks together), you're helping. - Amanda Morrison [more]
Unread 17-02-2011, 18:47
jackdawg's Avatar
jackdawg jackdawg is offline
AKA: Wyatt Cerilli
FRC #1307
jackdawg is an unknown quantity at this point
labview update messed up driver station.
we just installed labview update 3.2 and now our driver station (2010 netbook driver station account) gives us an error "executable version (8.6) doesn't match resource file (8.6). check your configuration"
anyone else get this error.
thanks in advance
-Wyatt C FIRST Team 1307
Unread 17-02-2011, 22:33
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: labview update messed up driver station.
I've not heard of that specific error.
However, other resource file issues have been traced to people trying to run the updater from within the .zip file without extracting it first. You might try redoing the update, making sure to extract everything before running it.
Unread 18-02-2011, 08:58
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
thanks in advance
I would extract the zip and try installing again to see if that fixes it. Let us know if it does.
Doug Norman
Unread 18-02-2011, 23:50
toastnbacon toastnbacon is offline
AKA: James
FRC #3169 (Saintborgs)
Rookie Year: 2010
toastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the rough
I got the same error just earlier today. I just restarted my computer, and I was able to pull it up like normal! Although I'm now having problems with getting Labview to open... If you get that problem too, I'd be happy to assist figuring it out!
"This must be what going insane feels like."-Simon Tam, Firefly
