Go to Post Either you have it hooked up wrong, or you have the Battery of the Gods. Probably filled with Mountain Dew... - nighterfighter [more]
Unread 18-02-2011, 15:50
Thomas DeSilva's Avatar
Thomas DeSilva Thomas DeSilva is offline
Programming Fury
FRC #1983 (Skunkworks)
Thomas DeSilva is on a distinguished road
Functional encoder returning 0
We have three US Digital quad encoders on our robot this year. We've implemented the fake encoder workaround for GetRate(), and the two encoders that we need to get rate out of are working fine, but the third, which we only need distance out of, never registers any change. The following code contains the contructors for all of our encoders:
Code:
fakeEncoderA = new Encoder(6,1,6,2,false, fakeEncoderA->k4X);
leftEncoder = new Encoder(4, LEFTMOTORA, 4, LEFTMOTORB, false, leftEncoder->k4X);
//fakeEncoderB = new Encoder(6,3,6,4,false, fakeEncoderB->k4X);
liftEncoder = new Encoder(4, LIFTMOTORA, 4, LIFTMOTORB, false, liftEncoder->k4X);
rightEncoder = new Encoder(4, RIGHTMOTORA, 4, RIGHTMOTORB, false, rightEncoder->k4X);
//fakeEncoderC = new Encoder(6,5,6,6,false, fakeEncoderC->k4X);
//liftEncoder = new Encoder(4, LIFTMOTORA, 4, LIFTMOTORB, false, liftEncoder->k4X);
The lift encoder is the one that doesn't register change. We have verified that the encoder works by plugging it into the left encoder's ports and reading it as the left encoder. We have also verified that the pins that the encoder is plugged into are working by successfully reading the left encoder off of them. The lift encoder still doesn't read if we comment out all of the other encoders, change the order of the constructors and declarations, or change the encoding type to 2X. Also, if none of the encoder constructors are commented out, the console constantly throws an "Assertion Failed" error from line 217 of Encoder.cpp in WPILib. I assumed that was because the FPGA can't handle 6 4X encoders, but changing them to 2X or 1X didn't help. Does anyone know how to solve this problem, or what's causing it?
Unread 18-02-2011, 16:44
davidalln's Avatar
davidalln davidalln is offline
World's Worst Coder
AKA: David Allen
FRC #2415 (The Westminster Wiredcats)
davidalln is on a distinguished road
Send a message via AIM to davidalln
Re: Functional encoder returning 0
Did you run Encoder->Start() before you try to get values? That's tripped me up before.
SANTOSH ANDREW DECKER RICK WYNNIE SEAN DEREK MATT
(alamo (semis), p'tree (CHAMPS!), nc (CHAMPS!), newton (quarters))
Best four years of my life. Thanks to everyone who made it happen.
Unread 18-02-2011, 16:52
Programming Fury
Well, that's embarassing. So, the lift encoder is now reading, but is there any insight on why I can't run more than four 2X encoders?
Unread 19-02-2011, 21:54
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
The wpi library user's guide talks about how there are only 4 modules in the FPGA on the CRIO that can run more 4x encodings, and they are probbly used to run 2x if you specify that mode.
Brian K
Team 1225 Robotics Mentor
