Go to Post ...thinking and learning never go out of style. - Rick TYler [more]
Unread 18-02-2011, 16:33
Ian McShane Ian McShane is offline
FRC #3585 (Rogue Robots)
Ian McShane will become famous soon enoughIan McShane will become famous soon enough
Arm problem with PWM in teleop code
We have 2 motors on our arm, i have the 2 motors in teleop, begin, finish, and autonomous vi's. When i go into the front panel of the set output motor vi in teleop to change one to PWM 5 and the other to PWM 6, but when i close them out and reopen them, they change to become the same PWM. either 5 or 6. I need one to be 5 and one to be 6, how do i change this?
in FIRST, it's process over product, and team over robot.
http://www.roguerobotsof4h.com/
Team 3585 Rogue Robots of 4-H
Unread 18-02-2011, 20:12
dahlboy15 dahlboy15 is offline
Vice President
AKA: Dyson Dahl
FRC #3290 (Robo-Bears)
Rookie Year: 2010
dahlboy15 is an unknown quantity at this point
Re: Arm problem with PWM in teleop code
I'm not sure what motors you are using, either window or jaguars but there is a terminal on the vi that you can right click and choose create constant and then select the PWM option. Save and then reopen and it should be the same.
Unread 19-02-2011, 14:09
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by Ian McShane View Post
When i go into the front panel of the set output motor vi in teleop to change one to PWM 5 and the other to PWM 6,...
You should not be changing anything inside those functions. You need to wire things to the function inputs. One of the inputs to the Set Output function is a "device reference", which you need to get from the output of a "Refnum Get" function.
Look at the motor control example, and then look at Tutorial 7 - Integrating Examples into Robot Code for detailed instructions. The tutorials are accessed from LabVIEW's Getting Started window.
Unread 19-02-2011, 21:13
MattCarey3625's Avatar
MattCarey3625 MattCarey3625 is offline
#3625 Programming and Wiring Head
FRC #3625 (Some Assembly Required)
Rookie Year: 2011
MattCarey3625 is an unknown quantity at this point
Anything involving PWM should remain constant. There is no reason I can thin of that would require you to use the front panel between stages. Use a 'Constant' instead of 'Control'.
matt@hp-mini-110$> sudo make robot
sudo pass for matt:
unable to make robot
