Go to Post You know those gravitational waves you keep hearing about recently? Those weren't created by colliding black holes, they were created by our boulders colliding with the opposing alliance's tower. - JohnFogarty [more]
Unread 18-02-2011, 17:05
FenrisKiba's Avatar
FenrisKiba FenrisKiba is offline
FRC #2603
FenrisKiba is an unknown quantity at this point
Camera dislikes cRIO
We are trying to set up a camera and are having a very strange issue. While the camera seems to work with older cRIOs (with the exact same code and image) it doesn't want to show anything with this years. All help would be appreciated.
Unread 18-02-2011, 19:39
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Camera dislikes cRIO
Are the case of the cRIO and camera shorted to the frame? They shouldn't be.
Unread 19-02-2011, 10:59
FenrisKiba's Avatar
FRC #2603
No they are not
Unread 19-02-2011, 13:34
marsperson2 marsperson2 is offline
FRC #2603
marsperson2 is an unknown quantity at this point
The code has been confirmed to be correct, what is happening is when we plug the camera into the cRIO, both the green and yellow lights are solid and we think that the yellow light is supposed to be flashing
Unread 19-02-2011, 14:14
Daiane's Avatar
Daiane Daiane is offline
AKA: Daiane Rodrigues
FRC #1772 (Heitortec Trail Blazers)
Team Role: Coach
Daiane will become famous soon enoughDaiane will become famous soon enough
Send a message via MSN to Daiane
Hi,
I'm using the camera AXIS 206.
My camera was runnig before I did the drive station and the 3.2 labview update. after this the camera didn't show in the dashboard(drive station).
and when i passed the code to the robot, there are errors about the camera.
can you help me?
Unread 19-02-2011, 16:25
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Is the camera reset switch being pressed accidentally?
Unread 19-02-2011, 16:32
Daiane's Avatar
Team Role: Coach
no, i didn't press the switch reset.
but if i pressed what i need to do?
thank you!
Unread 19-02-2011, 20:41
Software Architect
Basically...let go of it.
Unread 20-02-2011, 12:16
FRC #2603
The reset button is not being pressed for us, but we have tried resetting it and it didn't work
