Go to Post Remember, everything you do while on the team reflects on your team. Good reputations are difficult to build and easily destroyed. - Daniel_LaFleur [more]
Unread 18-02-2011, 20:31
winglerw28 winglerw28 is offline
FRC #1274
winglerw28 is an unknown quantity at this point
PSI Value for a Case Structure
I am used to C and C++ "if" statements, and I am wondering how I can plug the value of a digital input (connected to a pressure sensor) into a case statement so that our pneumatics compressor stops at 120psi.
Thank you,
Will
Unread 18-02-2011, 20:44
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: PSI Value for a Case Structure
The WPI Robotics Library includes a compressor class which handles everything automatically.
To answer your question generally, the digital input vi gives you a boolean (true/false) value. You can wire that directly into a case structure.
Unread 19-02-2011, 05:37
The case structure will also alloy you to connect an integer and you can type expressions in the case string such as ...
4..10
Default
You can also wire a string and put in string based expressions. You can wire error wires, and of course, enumerations.
Greg McKaskle
Unread 19-02-2011, 08:23
FRC #1274
Thank you very much!
This is the first time programming pneumatics, and I'm having a hard time with it since I'm pretty much just using LabView without ever really exploring it. Your help is immensely appreciated.
