Go to Post We should also remember the fact that the FIRST Manual is not supposed to be enterpreted with lawyer speak. If so you could make it say many things. - Anthony [more]
Unread 18-02-2011, 22:22
lucoytoa's Avatar
lucoytoa lucoytoa is offline
Programmer
AKA: Nicolas Xiong
FRC #2276 (STARS of Cypress)
lucoytoa is an unknown quantity at this point
Please Review My Autonomous Codes
Please help review my autonomous code with line tracking. We haven't tested it yet so if you see anything wrong let me know. The sequence begins
after the sensors have reached the T.
We will be testing it tomorrow at a scrimmage.
FRC - STARS of Cypress, 2008, 2009, 2010
FTC - SOAR Club - 2011
FLL - DNAbots - 2009, 2010
BEST - STARS of Cypress - 2008, 2009, 2010
MATE - STARS of Cypress - 2008
MATE - SOAR Club - 2011
VEX - Discobots - 2010
Robofest - 2008
Houston: Energy City of the Future - RNKL Engineering - 2009
Unread 19-02-2011, 07:24
Re: Please Review My Autonomous Codes
There are a number of things you may want to change. First off, unless you have disabled the safety for the motors, you cannot set the speed of a motor and simply leave it on for 1 or two seconds. If you don't tell it to stay on, it will turn off after 100ms.
I've attached a VI that I really wish we'd put into the palettes. It works the same as last year's Delay and Feed VI, but instead of feeding the watchdog it updates the given motor. You can use it like the delay block, but wire in seconds, and also wire in the error I/O for sequencing and the motor refnum for updating. Don't worry too much about the nap time input.
The snapshot shows what the equivalent diagram looks like with this. I've also attached a subVI, Autonomous Clipboard.vi, with the code --in case you want to copy/paste instead of rebuilding it.
Be sure to put the WPIMotor...DelayAndFeed VI into Program Files\National Instruments\LabVIEW 8.6\vi.lib\Rock Robotics\WPI\Motor Control folder before you use it.
Other considerations? -1 seems really fast to be reversing the robot for three seconds while moving the arm. I suspect that you'll need to dial that down. I also wouldn't be surprised if you need to lower the arm and then start backing up. But that dead-reckoning adjustment is something you should work out at or during the scrimmage.
Good luck.
Greg McKaskle
Name:	Screen shot 2011-02-19 at 6.12.08 AM.png
Unread 14-03-2011, 20:52
jhellr13 jhellr13 is offline
FRC #4272
Rookie Year: 2010
jhellr13 is an unknown quantity at this point
Good luck.
Greg McKaskle
Hey Greg
I have a week before my team competes at our regional, and i am still attempting to make an autonomous mode. Our robot is basically a 6wd arcade drive with 4 motors. We are unsure about using the sensors because we haven't mounted them yet. My mentors wanted me to write a code for the line sensors, and one for if we don't have the line sensors. For the code without the line sensors, i was trying to use your attached code, but i ran into a problem because our arm is a relay, not a motor like shown, and i couldn't figure out a way to make it work. For the code WITH the line sensors, i have having trouble finding the spot to add my extra stuff. I know to keep the default line code, but we want some other things done. This is what we are trying to attempt in order of occurence: Follow the line to the T. Not following the Y. Next, or as its moving, raise our arm for x amount of time. Our arm is run by a spike relay. Next, have the robot move forward for let's say half a second to put the tube over the peg. Next, have the arm drop for x amount of time. Lastly, drive away for x seconds. Its a long wish list, but it would mean a lot. I'm a rookie programmer, and if i can get autonomous working with the help of others, would be a great feeling. All the timing and such, i can figure out, i am just stuck in where to put the stuff and how to make this code effectively.
Thanks,
Jared
Unread 15-03-2011, 23:00
If I understand what your idea, you want to move the arm independently and begin the loop that follows the line.
My suggestion would be to use timers, relays, and a sequence structure to do the arm in parallel with the line follower code. Put code after the line follower loop that will reverse the relay for some time, release the tube, and drive away.
I know that isn't a ton of detail, but start with the initial stuff and once it works, add the next element in. Once you get started, I think the sequencing will become more obvious.
Greg McKaskle
Unread 16-03-2011, 21:21
FRC #4272
Rookie Year: 2010
Greg McKaskle
Hey Grey,
Yes, I want the robot to first follow the lines, then raise the arm once the robot reaches the T. I have my autonomous code posted at this link. http://www.chiefdelphi.com/forums/sh...=check+my+code
