Go to Post Flash drive? I was thinking floppy disks... :ahh: . - MrForbes [more]
Unread 18-02-2011, 23:14
Slayersheron Slayersheron is offline
FRC #3360
Slayersheron is an unknown quantity at this point
Driver Station problem
Sorry for asking another question so quickly, but we have a problem with the Driver Station, once uptaded, LabView is still working, but the Driver Station writes this message:
Executable version (8.6) doesn't match resource file (8.6).
Check your configuration
I'd like to know if there's a way to fix this, I tried to install it again but it didn't change anything
Unread 19-02-2011, 03:00
bls0620's Avatar
bls0620 bls0620 is offline
FRC #0368 (Team Kika Mana)
bls0620 will become famous soon enoughbls0620 will become famous soon enough
Re: Driver Station problem
It sounds like there's a mismatch between your executable and resource file. Try check the versions on your files and make sure they are the same. If not, update both files. (I'm just throwing it out there. It's been a year since I touched LabVIEW, thanks to college )
If I'm wrong let me know. I'll try to figure something out
Unread 19-02-2011, 14:48
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
When you updated LabVIEW, some supporting "stuff" changed. You just need to Build your project and Run as startup again in order to make your deployed code match the updated "stuff".
