Go to Post They were designed that way so they would be compatible with the water-based ga.... oops, sorry, we aren't supposed to say anything about that. Never mind. - dlavery [more]
Unread 19-02-2011, 11:00
hornetshornets's Avatar
hornetshornets hornetshornets is offline
FRC #1816
Rookie Year: 2010
hornetshornets is an unknown quantity at this point
Camera image not showing up with new driver station update
Cant figure out how to get this image onto the drivers station. We've proven that the camera is set up correctly but the image won't show up we just see a white screen
A man once turned his car into the shop with a complaint that read “Unfamiliar noise from engine.” The next day, the car was ready for him. The engineer’s logbook entry read “Ran engine continuously for four hours. Noise now familiar.”
Unread 19-02-2011, 15:05
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Camera image not showing up with new driver station update
What language are you using to program your robot?
Unread 19-02-2011, 15:15
Daiane's Avatar
Daiane Daiane is offline
AKA: Daiane Rodrigues
FRC #1772 (Heitortec Trail Blazers)
Team Role: Coach
Daiane will become famous soon enoughDaiane will become famous soon enough
Send a message via MSN to Daiane
Hi,
i'm with the same problem and i'm using labview.
and when i passed the code have some errors about the camera
Unread 19-02-2011, 17:20
FRC #1816
Rookie Year: 2010
We use c++ java and labview and were having problems with all. We would like to focus on java or c++
Unread 19-02-2011, 20:54
Software Architect
Originally Posted by hornetshornets View Post
We've proven that the camera is set up correctly...
How have you done that?
