Go to Post By the end of the year, I have a feeling that I'm going to know much, much more about the intricacies of orbit balls than I ever wanted to. - Jared Russell [more]
Unread 19-02-2011, 11:43
winglerw28 winglerw28 is offline
FRC #1274
winglerw28 is an unknown quantity at this point
Help Getting my Compressor to Work
Ok, so I have learned how to program a compressor, but cannot for the life of me get it to work at all.
I have it set up in the digital sidecar Relay slot 1, and the pressure valve sensor in DIO 4, and I have ensured that there are no conflicts with that. I have in Begin.vi the declaration of the compressor and the start, as well as a refnum for the compressor.
When I turn the code on, it doesn't seem to be sending any information to the Spike i have the compressor hooked up to. If anyone can point me in the general direction, that would be fantastic, thank you.
EDIT: Also, the relay lights on our digital sidecar are not lit... Is this a problem?
Unread 19-02-2011, 12:50
Flyer522's Avatar
Flyer522 Flyer522 is offline
AKA: Holton
FRC #3753 (Raptor Robotics)
Team Role: Leadership
Rookie Year: 2010
Flyer522 is an unknown quantity at this point
Re: Help Getting my Compressor to Work
When you say relay lights you are talking about the BAT, 5V, and 6V lights correct? If so we ran into that problem, and it did cause some problems. Simple fix though because the wire was not the correct size; a member of the team accidentally put a smaller wire on the ground connection so it was not working. Maybe that will help not really sure though.
Team 3753 | Raptor Robotics
2011 Bayou Regional Highest Rookie Seed Award
2011 Bayou Regional Quarter-Finalist (w/ 1912 & 3672)
2012 Bayou Regional Quarter-Finalist (w/ 1912 & 1927)
Data is not information.
Information is not knowledge.
Knowledge is not understanding.
Understanding is not wisdom.
Unread 19-02-2011, 13:34
FRC #1274
No, I mean the actual relay indicator lights were not flashing when output was used. I replaced the board and it's all ok now, working fine.
Thank you for the help, however
