Go to Post This is one area where you want an old hand in the room to show you how to work on this thing. .... If you survive it, electricity hurts really bad. - ebarker [more]
Unread 19-02-2011, 11:49
Brandon_L Brandon_L is offline
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Rookie Year: 2007
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
Potentiometer wont work
We can't seem to get our potentiometer to work in labview.
We wired it and checked it with a volt meter, as we turn it the voltage on the signal wire does change. We just can't get any value to show up in an indicator in labview
We are using the analog get voltage vi
FRC 2495 - Hamilton West Robotics [2007-2014] - whats a..."hive mind"?
FRC 3929 - Atomic Dragons [2012-2013]
FRC 2180 - Zero Gravity [2017-]
Just trying to collect all the possible team colors
Unread 19-02-2011, 15:17
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Potentiometer wont work
Please tell us exactly how you have it wired. Which connector is it going to? Which wires are connected to which pins on the pot?
We can't help you if we don't know what your wiring and your code look like.
Unread 19-02-2011, 19:29
AKA: Brandon Liatys
Rookie Year: 2007
red attached to one of the outer ones, black to the other outer, with white in the middle (As I read on many threads, this is how to do it). A cut PWM wire, of course. The other end is plugged into the analog breakout (#1 on the breakout, in slot 1 of the cRIO).
All the same settings were used in the programming.
Unread 19-02-2011, 21:44
Software Architect
The wiring sounds right for a typical single-turn potentiometer (many multi-turn pots have the wiper terminal at the end).
How are you trying to show the value? Let us see your code.
Unread 19-02-2011, 22:50
AKA: Brandon Liatys
Rookie Year: 2007
The laptop is kept at the school so I wont be able to get to it until monday, but basically:
In open:
Open analog input, slot one and channel one, set ref, error into the error out
in teleop, get ref, then get voltage with the voltage wired to an indicator
and in finish, we close it.
Unread 20-02-2011, 00:32
Software Architect
Don't forget that Teleop runs only when the robot is enabled. You won't see anything change on the indicators if the robot is disabled.
Unread 20-02-2011, 01:11
WizenedEE's Avatar
WizenedEE WizenedEE is offline
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Team Role: Leadership
Rookie Year: 2010
WizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to all
Did you plug it into the analog breakout so that it matches the wiring diagram on the side? The -, on the side closest to the PWM-holder-inner thing, should be the black wire, the middle should be red, and the "Sig" should be the white one.
What output are you getting from the indicator? 0? 5? Is it giving random numbers? Does the value go down when you turn the pot up? Does it change with the pot, but in a weird way?
Random numbers probably means not connected, 0 would probably mean teleop isn't enabled. If it changes in a weird way when you turn the potentiometer, you might have the PWM cable in the analog breakout backwards. If the value is inversed of what you think it should be, either reverse it in the code (I guess that would be later) or swap the red and black cables.
Unread 20-02-2011, 10:36
jmanela's Avatar
jmanela jmanela is offline
+1 is BIGGER than -1
AKA: Joshua Manela
FRC #2586 (Fondy Fire)
jmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to behold
Try using the Analog Input Example that NI gives you before further testing so you can rule out electrical problems.
When the LabView splash window opens, go to the bottom right corner and click FRC examples, go to the analog folder and click the Analog Input Example. Make sure you set the IP of your robot when you open up the Analog Input Example project.
||2009|| Entrepeneurship Award, QF - Traverse City | Rookie All Star, QF - Detroit | Highest Rookie Seed, Rookie All Star, QF - Michigan State Championship | Finalist - MARC ||2010|| Engineering Inspiration, Website Award, SF- Kettering | Judges Award, Website Award, SF - Detroit | Website Award, Winner, Michigan State Champ //Thank you 469 and 1918!! | Finalist - MARC ||2011|| Engineering Inspiration, Website - Kettering | Entrepreneurship, Website, Finalist - Waterford | Website - MSC
Unread 20-02-2011, 19:53
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Here is what I did to show the value which I think is your problem. It writes a string to the driver station and you can look at it when the robot is running.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
