robot code not deploying
Hey guys sorry if this has been posted but when I build an run as startup or when I I run hr robot main code it goes through the steps of deploying and we open up the driver station it gives us a red light next to robot code
Re: robot code not deploying
Check the version of the cRIO image. Also, does the VI run interactively, using the run button?
Greg McKaskle |
Check to make sure your image in the cRIO Imaging tool is not 'unknown' and try restarting the robot. We have this problem quite frequently as well.
Just to make sure:
You aren't quitting LabVIEW before starting the Driver Station application, are you? |
