Go to Post I have long since given up on these hints, and come to the conclusion that they are designed to befuddle us all and amuse Dave. - Rickertsen2 [more]
Unread 19-02-2011, 14:21
dungeonmonkey dungeonmonkey is offline
FRC #2458
dungeonmonkey is an unknown quantity at this point
Exclamation Magnetic Rotary Sensor Programming
I am having issues figuring out what the outputs are from our austria microsystems magnetic rotary sensor (AS5030). I have declared them as DigitalInputs but cannot figure out how to use them in the code. I tried debugging it by setting up printf statements and cout statements, but I could not get the console to come up properly, even after following many guides about it (has issues getting information about the target).
Team modo: "I'm sure it's around here somewhere..."
"If at first you do not succeed, you fail." -Glados
Unread 19-02-2011, 16:48
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Magnetic Rotary Sensor Programming
You can configure them to be analog ("filtered PWM"), straight PWM, Analog Sine-Cosine, and 4-wire SPI.
One thing they are not is a boolean digital input.
See the 2011 Sensor Manual, available from the Kit of Parts web page.
