Go to Post I normally prefer my speed controllers to brake, rather then break. - Joe Ross [more]
Unread 19-02-2011, 15:01
winglerw28 winglerw28 is offline
FRC #1274
winglerw28 is an unknown quantity at this point
How to use Solenoids attached to Relays
Here is my current teleop vi, but nothing happens when I press button 8 on the joystick:
Help would be greatly appreciated, as I'm getting extremely frustrated.
Unread 19-02-2011, 15:35
Wicked Wicked is offline
FRC #0354 (G-House Pirates)
Wicked is an unknown quantity at this point
Re: How to use Solenoids attached to Relays
That's because the case structure is wired to Button 1.
Unread 19-02-2011, 15:54
FRC #1274
Sorry I just re-did that after deleting. It still doesn't work after being assigned to button 8.
Unread 19-02-2011, 17:57
stormyweathers stormyweathers is offline
FRC #3653
stormyweathers is an unknown quantity at this point
what is the value of "On"
maybe that isnt set properly.
do relays need a "1" wired to be on?
Unread 19-02-2011, 18:09
FRC #1274
This is the way I programmed last years robot. This year it was working and just stopped for some mysterious reason.
Unread 19-02-2011, 20:18
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Usually, Relays use the "Forward/Reverse" choices to run motors or operate solenoids.
Only under special wiring conditions for solenoids is "On" used.
Unread 19-02-2011, 22:20
FRC #1274
Could some post a picture of a correctly programed relay so i can compare? I still can't get it to work.
Unread 20-02-2011, 11:23
Just Itinerant
Just to make sure you don't have a simple wiring problem instead.
Are the Relay LED indicators located on the Digital sidecar turning red or green as you use button 8?
I assume it's a motor you're trying to have move only while you hold button 8?
Is it a one-way motor that goes out, but gets physically pushed back?
This is just what you posted.
It makes the Digital sidecar green Relay LED come on.
Unread 20-02-2011, 19:40
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
I'm not sure why your not using the solenoid breakout that's already in the WPI library WPI Robotics Library> Actuators> Solenoid> Set. And then for a double acting solenoid you open 2 different ports. See picture.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
