Go to Post you are never an alumni of FIRST, you can always be there, mentoring, learning, creating. - KelliV [more]
Unread 19-02-2011, 16:24
Lucas_bobier Lucas_bobier is offline
FRC #2509
Lucas_bobier is an unknown quantity at this point
Motors Jumping
Hey I need some help,
This year our team decided on meccanum wheels and we created a working code, however today our wheels started then stopped briefly then starts again even if we are pushing the joystick continuously. its like it stutters.
Any help will be greatly appreciated.
Unread 19-02-2011, 20:36
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Motors Jumping
Step 1: check your battery voltage.
Unread 19-02-2011, 21:19
MattCarey3625's Avatar
MattCarey3625 MattCarey3625 is offline
#3625 Programming and Wiring Head
FRC #3625 (Some Assembly Required)
Rookie Year: 2011
MattCarey3625 is an unknown quantity at this point
Re: Motors Jumping
Do you have a vi you could show? You don't have to, but I have found that either 1( battery is low on charge or 2( you code is too large and cluttered and could A( be submitting conflicting values or B( causing a lag. B may not actually happen but we had this problem yesterday and a combination of the two fixed it for us. Good luck!
matt@hp-mini-110$> sudo make robot
sudo pass for matt:
unable to make robot
Unread 19-02-2011, 21:43
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: Motors Jumping
I second Alan's advice regarding battery. I also believe that your (I assume) 40A circuit breakers feeding (I assume) CIM motors are tripping.
These may or may not be related.
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
