Go to Post Are they Robots? Of course they aren't robots; they are obviously and unambiguously robots. - gblake [more]
Unread 19-02-2011, 22:33
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Rookie Year: 1999
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
2D Array
Okay, I've search, I've read help, I've looked at examples, but I can't seem to figure out how to create a simple 2D array of static values on the front panel.
What I'm trying to do is have a 2D array 3rowsx2cols on the front panel with static numeric values. This array, I want to index on the block diagram to retrieve the number from that row and column based on some switch settings at the driver station.
Could someone point me in the right direction
Thanks
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 20-02-2011, 00:23
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: 2D Array
The second item in the Functions Palette is the Array sub-palette. The bottom left item there is an Array Constant.
To make it into a two-dimensional constant, right-click and choose Add Dimension. Drop a numeric constant into the empty square on the right to set the type of the array. Now you can grab the resizing handles on the (now much smaller) square and make it as many rows and columns as you want.
Unread 20-02-2011, 11:28
Phalanx's Avatar
Rookie Year: 1999
Re: 2D Array
Thanks Alan,
Much appreciated. That was very easy.
