Go to Post … it’s all good as long as the kids are inspired. - AdamT [more]
Unread 20-02-2011, 14:46
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Team Role: Coach
Rookie Year: 2010
Robby Unruh will become famous soon enough
Help please
okay we have our compressor wired, we turn the bot on and nothing happened. if anyone can help us our problem, please message back quickly. thanks
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 20-02-2011, 15:11
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Help please
Just to check:
Power flow: PDB->Spike->Compressor
Signal: cRIO-> Spike via PWM
Pressure sensor attached to cRIO
If any of those are wrong, you need to fix it.
The Spike has a 20A fuse. Is it blown? Has it been replaced with a 20A Snap-Action breaker?
Has the robot been enabled with the compressor onboard?
Do you have the appropriate compressor code in your code?
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 20-02-2011, 17:37
BHS_STopping's Avatar
BHS_STopping BHS_STopping is offline
The Freshman
FRC #0842 (Falcon Robotics)
BHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant future
Re: Help please
1726 had a similar problem a few weekends ago. We noticed that when we pushed on the output terminals of the spike connected to the compressor, it would turn on. We took apart an old spike but we didn't see anything wrong.
Turned out it was the new PWM cables we were using which were the problem. If you look at a new cable, you'll see that the pins have sort of a U-shaped profile when pointed towards your eye. These connectors seemed to jostle around a little bit and lose contact with the terminal inside the spike, and when we applied pressure to the outputs of the spike the PWM would make contact.
We then switched to an old PWM cable (which have "solid" pins) and they fit much better inside the spike. After we made the switch the robot didn't seem to have any more problems. Hope that helps!
[/The Freshman]
Unread 20-02-2011, 18:00
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Help please
Of course, he means "cRio --> Digital Sidecar --> Relay Output --> PWM Cable connected correctly to Spike".
Black must be on the correct pin on both the DSC and Spike.
OK, what's the LED in the Spike doing?
Is there software in the cRio to tell the compressor to come on when the switch calls for pressure?
