Go to Post "You know you're a robotics kid when you sit on Chief Delphi and hit refresh over and over again waiting for new pictures and videos of other teams" - pwnageNick [more]
Unread 21-02-2011, 07:21
java4first java4first is offline
(Java) Programming Mentor
AKA: Stu
FRC #0501 (Power Knights)
Rookie Year: 2011
java4first is an unknown quantity at this point
New FRC cRIO Image & NetBeans & Eclipse
Hi -
We are using Eclipse as our IDE. This morning I pulled down the new cRIO image and the new NetBeans plugins and installed them (since that used to be the only way to get the cRIO image update).
However, when I connect Eclipse to the WPI site to pull down the new corresponding Eclipse plugin updates, it says the old ones are the latest. Does that mean Eclipse didn't need to change, or is it just not published yet.
Our development lab has limited external internet access, so I'm trying to get all the required updates before going in this morning.
Thanks!
Stu
