Go to Post Getting a swerve to drive predictably and effectively is arguably harder than designing and building it. - Holtzman [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 21-02-2011, 11:44
ArchVince's Avatar
ArchVince ArchVince is offline
FRC #1290 (Si Se Puede)
Rookie Year: 2010
ArchVince will become famous soon enough
Axis Camera 206 Problems
I connected the camera to the Classmate, and ran the setup tool. The first time, it failed. The second, it said it was successful. I went to plug it in and test it, and no picture showed up on the default dashboard. I looked at the lights to make sure nothing was wrong, and it appears something is very wrong. The camera repeatedly resets. I know about the black reset button; I took care to not hold it down. I held it by the front of the casing. I went into the camera through the browser, and I get the live feed working. After about 30 seconds, the signal light on the back of the camera suddenly goes out, as does the light on the front of the robot. The power light remains lit. After about 15 seconds, the signal light turns orange, and it begins the boot with the amber front light. Sometimes it boots correctly and it is running for 30 more seconds; other times the lights go out again during the boot. Anyone have any ideas on how to fix it? This is the 206 camera.
PETA wants your help finding Schrödinger.
