Go to Post I don't mean to sound harsh, but I do not want you to get your hopes up. There are deadlines in FIRST. - RoboMom [more]
Unread 21-02-2011, 11:54
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
LEDs connected to Solenoid Breakout. It's illegal, but why?
From the rules, it is illegal to connect anything but solenoids and the line sensors to the solenoid breakout. We have 3 LED strings, pulling about 300mA a piece. We would love to save some space and connect them to the solenoid breakout board, but guess what...
<R60> Solenoid Breakout outputs shall be connected to pneumatic valve solenoids or photoelectric sensors, PN 42EF-D1MNAK-A2, only. No other devices shall be connected to these outputs.
Any reason why custom circuits are not allowed? It's adding unnecessary complication to our already over complicated robot.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 21-02-2011, 12:07
DonRotolo's Avatar
Back to humble
FRC #0832
Re: LEDs connected to Solenoid Breakout. It's illegal, but why?
The only reason that matters is because it is in the rules. Same reason we're not allowed to use Duct Tape on the minibot.
I can speculate that they are concerned that teams will draw too much current from the breakout and make their pneumatics uncontrollable or erratic.
Side note: a 300 mA LED is about 1 watt. This will be BLINDINGLY bright.
Unread 21-02-2011, 12:30
RyanN's Avatar
RyanN
Yep, they're pretty bright all put together. I think there are about 30 LEDs in the string.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 21-02-2011, 13:17
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The NI 9472 Digital Sourcing Module has protection against extreme overcurrent, so you probably wouln't be able to cause any fires, but the documentation warns that at currents between 1 and 13 amps the module "may be damaged".
Unread 21-02-2011, 14:38
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Team Role: Leadership
Rookie Year: 1998
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
Believe me, my students were a bit ticked at this as well.
The solenoid breakout is simply the BEST way to power your LED light indicators.
Unfortunately, from my reading of the rules, that would be illegal.
I agree that we would all benefit from a loosening of the rules of what can be hooked up to the solenoid breakout to include custom circuits < 500mA.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 21-02-2011, 15:16
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
I believe the best way to handle this is to make the request in the Q&A.
The wording for the rule change that would allow this would be awkward, as the solenoid breakout can sometimes be used with the 24V rail. I would hope that the rule change would not allow using that rail for LEDs.
Unread 01-02-2012, 08:54
Bendito's Avatar
Bendito Bendito is offline
AKA: Benjamin LaRoche
FTC #7837 (The Thunder Colts)
Rookie Year: 2011
Bendito is an unknown quantity at this point
Does this rule apply to the 2012 season, as I can't find anything that specifically prohibits the LEDs in this year's manual?
Unread 01-02-2012, 09:10
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I think the applicable rule this year is:
[R63]
Outputs from each Solenoid Breakout shall not cumulatively exceed 16W for the cRIO-FRC (8-slot) and 21W for the cRIO-FRC II (4-slot).
Unread 01-02-2012, 09:35
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
There are other ways to control LEDs that do not include the solenoid breakout. 300 ma is (As Alan has pointed out) excessive for the solenoid module. The manufacturer recommends 75 ma per output as a safe use of this module. It is for this reason that electric solenoid actuators or 10 watts or less can be driven from this module as well.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 01-02-2012, 10:19
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
I'm curious why you think a 300 ma led is excessive but an 800 ma solenoid is ok.
Unread 01-02-2012, 10:24
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
The datasheet for the Solenoid Breakout board specifies 750mA per output channel.
Unread 01-02-2012, 12:43
Unsung FIRST Hero
Rookie Year: 1996
Sorry,
Left off the last zero. 750 ma at 12 volts is 9 watts.
Joe, I was considering the total for LEDs for three strings plus the loads likely for other devices as totaling more than one amp. As Alan reminded me last year the manufacturer has this rather odd table listing for trip modes. One of those lines for total current is this...
"1 to 6 A, Channel does not trip, Module may be damaged."
Al
WB9UVJ
www.wildstang.org
Unread 01-02-2012, 13:34
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
A Spike may be bulkier, but you could use one spike to switch two banks of LEDs by wiring each motor output to the positive side of the LED and running the common directly back to the PDB.
Unread 01-02-2012, 14:33
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Alternatively, a simple transistor LED driver can be made. Use one digital out pin per LED string.
The driver only needs one CORRECTLY SIZED resistor and transistor per string to work. Just use +12vdc to power it, and control it via the DSC.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
  #15   Spotlight this post!
Unread 01-02-2012, 14:40
Aren_Hill's Avatar
Aren_Hill Aren_Hill is offline
Build Nifty Things
Aren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond repute
Sorry,
So if i had an LED strip rated at 200ma (12v) It'd be alright to run off the solenoid breakout?
If its only one strip and minimal other things using the breakout
A guy who likes robots.
1625->3928->148->1296->971 oh dear
