Go to Post FIRST is nothing short of a community. - karinka13 [more]
Unread 21-02-2011, 16:19
Ian McShane Ian McShane is offline
FRC #3585 (Rogue Robots)
Ian McShane will become famous soon enoughIan McShane will become famous soon enough
motor vs servo
if i have a motor programmed to move when i hit a button, will a servo move if it is wired the same.
in FIRST, it's process over product, and team over robot.
http://www.roguerobotsof4h.com/
Team 3585 Rogue Robots of 4-H
Unread 21-02-2011, 20:52
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: motor vs servo
Quick answer: no.
When you set a servo output value, the servo will turn to a specific position and stay there.
When you set a speed controller output value, the motor will begin spinning at a specific speed. That's an extreme simplification, but it's close enough.
Unread 22-02-2011, 17:15
Re: motor vs servo
that is weird, a servo moved for us when we programmed a motor for the same pwm.
Unread 22-02-2011, 22:41
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: motor vs servo
It should move, then stop at a position relative to the input (joystick position, hardcoded constant) you are giving it.
If it's connected to a joystick it will follow the position of where the joystick is held.
Unread 22-02-2011, 23:01
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Re: motor vs servo
It won't stop if it's a continuous rotation servo, instead, it will act like a motor.
Unread 22-02-2011, 23:09
Just Itinerant
Re: motor vs servo
Yea, then it is just a motor and not a servo except in form factor.
The ones in the Kit are traditional servos, and that's what I assume.
