Go to Post I have a pocket full of Gracious Professionalism! How about you? - Schnabel [more]
Unread 21-02-2011, 16:19
2bkrul's Avatar
2bkrul 2bkrul is offline
Whats tht burnin smell..oh the Jag!
AKA: Brandon Krul
FRC #0964 (Bedford Robotics)
Team Role: Mechanical
2bkrul is an unknown quantity at this point
Programming help
I know im in the wrong section, but i need help. We are trying to set up two double port solenoids on our robot and i cant get them to work using labview. Someone please help!
"Building robots is a lot better with doughnuts around"
-Team 964 2010 Team Motto
Team 964 on TBA!
The Home of Bedford Robotics!
Unread 21-02-2011, 20:55
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Programming help
What are your solenoids connected to? Are they controlled with Spike relay modules, or are you using the Solenoid Breakout on the cRIO module in slot #8?
Unread 22-02-2011, 03:16
2bkrul's Avatar
AKA: Brandon Krul
We are using the solenoid breakout in slot 8
Team 964 on TBA!
Unread 22-02-2011, 04:46
Happy Birthday! reuven reuven is offline
FRC #3211 (The Y team)
reuven will become famous soon enough
all the functions for them are in the acutors section in the WPA robotics Libraryץ
Unread 22-02-2011, 07:41
Brandon_L Brandon_L is offline
The color orange triggers me
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Rookie Year: 2007
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
After you think the program should be working and you test it and it doesn't, don't shoot yourself in the foot yet. Check to see if the little lights next to the solenoid breakout are turning on and off as you press the buttons that should activate the solenoids. If they work, but the solenoid still doesn't activate, then you can shoot your electrical guys in the foot because the have a wire in backwards or upside down or something.
Just thought I'd share that.
And for the record, I never told you to shoot them
FRC 2495 - Hamilton West Robotics [2007-2014]
FRC 3929 - Atomic Dragons [2012-2013]
FRC 2180 - Zero Gravity [2017-]
Just trying to collect all the possible team colors
