Go to Post Beatings will continue until morale improves! - DampRobot [more]
Unread 21-02-2011, 16:43
Darker>Darkness Darker>Darkness is offline
Assistant Programmer
FRC #1378 (Green Label Zealots)
Rookie Year: 2011
Darker>Darkness is an unknown quantity at this point
Exclamation Servo Help needed
We are having issues with our servos. The issue is that it doesn't move at all, and we cannot tell if it is the servo's mechanical problem or a programming error. I'm attaching a screenshot of the program we have.
Any help is appreciated. Thanks in advance!
Unread 21-02-2011, 17:36
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
Rookie Year: 2010
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
Re: Servo Help needed
did you put a jumper where you inserted the servos on the Digital Sidecar?
