Go to Post While searching is not as glamorous, I'm certain you could find a lot of good resources related to this topic. - Katie_UPS [more]
Unread 21-02-2011, 17:45
Joseph W. Horth Joseph W. Horth is offline
FRC #0280
Joseph W. Horth is an unknown quantity at this point
Limit Switches
After a bit of search I couldn't find what I needed to know, so here goes; How should Limit Switches be wired in coding? I have a limit switch on each of the pivot points on our arm but when even one of them is hit it kills every function on the robot. It stores the inputs as I can see them on the driver station however, it won't let me move any of them. I've included both a picture of the Teleop.vi code and a picture of the Begin.vi, thanks for taking the time to read this.
ID:	10260  Click image for larger version
Unread 21-02-2011, 18:11
civ77 civ77 is offline
FRC #2521
civ77 is an unknown quantity at this point
Lightbulb Re: Limit Switches
It appears that you have name them incorrectly, you called it limit in begin and limit1 in teleop.
Unread 21-02-2011, 18:16
FRC #0280
Re: Limit Switches
I fixed that and am still having the problem. Help!
Unread 21-02-2011, 18:58
benjamin.narin benjamin.narin is offline
FRC #2521
benjamin.narin is an unknown quantity at this point
Re: Limit Switches
The code for the limit switch itself looks fine to me.
I'd look at the case structures it's wired to, wiring on the robot, broken limit switches. etc...
Unread 21-02-2011, 23:53
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Limit Switches
I'll bet you a bottle of Mountain Dew that you have your limit switches miswired between ground and the +5 pin of the DIO instead of the signal pin. As soon as a switch is hit, you'll short the Digital Sidecar's power and everything it's controlling will shut down.
Unread 22-02-2011, 00:59
bstites82 bstites82 is offline
AKA: Blake Stites
FRC #2164 (multiple)
bstites82 is an unknown quantity at this point
Re: Limit Switches
I'm not an expert, but from the code I can see you're logic goes true when the limit switch is activated, but you don't have an alternative argument to reverse the motor off the limit switch. I can see why this would disable the arm, but if its killing the whole bot there may be other issues.
Unread 22-02-2011, 09:22
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Re: Limit Switches
Try deleting those error wires because when you have that error in there and you trip the limit switch it is sending an error out which could potentially stop your whole robot.
Also as for your encoders your begin should have a Config Timer and Start VI in there too. I followed the Motor with Encoder Example
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 22-02-2011, 22:56
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
Team Role: Coach
Rookie Year: 1996
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: Limit Switches
In Begin.vi
