Go to Post When teams work together to design things rather than going it alone, you can really come up with magnificent machines. - JesseK [more]
Unread 21-02-2011, 18:27
katiebelle katiebelle is offline
FRC #1622
katiebelle is an unknown quantity at this point
Logitech Gamepad: Dpad programming?
Does anyone know what axis the dpad is called on the logitech controller?
Unread 21-02-2011, 18:37
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
FRC #0111 (WildStang)
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Re: Logitech Gamepad: Dpad programming?
You may want to check out the class that's posted here.
To directly answer your question though, it's a combination of axes 5 (x) and 6 (y).
Code:
if (x < -0.5 && y < -0.5)
        return kUpLeft;
    if (x < -0.5 && y > 0.5)
        return kDownLeft;
    if (x > 0.5 && y > 0.5)
        return kDownRight;
    if (x > 0.5 && y < -0.5)
        return kUpRight;
    if (y < -0.5)
        return kUp;
    if (x < -0.5)
        return kLeft;
    if (y > 0.5)
        return kDown;
    if (x > 0.5)
        return kRight;
    return kCenter;
Unread 21-02-2011, 19:40
FRC #1622
Thanks for the help.
