Go to Post It's a game. It's a challenge. Face it like a man, build a robot to play the game and get over it. - Arefin Bari [more]
Unread 21-02-2011, 23:26
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Rookie Year: 1999
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
pic: 179 Swampthing 2011
http://www.youtube.com/watch?v=oMx_S_H-a0I
http://www.youtube.com/watch?v=z4KUwIJrF0c
http://www.youtube.com/watch?v=bOxRFRwZ6uA
http://www.youtube.com/watch?v=tuUKcLoOBb8
Unread 21-02-2011, 23:27
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: pic: 179 Swampthing 2011
The claw!?!? it doesn't move!!?!?! I LIKE IT!!!!
Unread 22-02-2011, 00:11
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
Team Role: Coach
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
Wow, I am quite impressed with how effective a static gripper is. Nice job. Have you run your robot into walls, etc. to simulate active defense? Is your grip on the tube firm enough to withstand basal blows?
Cold Fusion's 10th Season
Unread 22-02-2011, 09:28
Jetweb Jetweb is offline
is good at making robots find walls
AKA: Jonathan
FRC #0179 (Children of the Swamp!!!)
Rookie Year: 2007
Jetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to all
The claw isent completely static, there are servos mounted into the pvc with fingers that hold the tube in place. there programed to open and close on there own at certain arm positions to keep them from getting destroyed. When there closed you cant get the tube out for anything.
Unread 22-02-2011, 09:42
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
FRC #0548 (Robostangs)
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
I hope your mini bot deployment is ok with G<22>
HOSTBOTS may not contact their ALLIANCE‟S MINIBOT while any part of it is above the DEPLOYMENT LINE.
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
Unread 22-02-2011, 09:54
AKA: Jonathan
Rookie Year: 2007
It is by about an inch, if they think were cutting it to close it can be lowered but it shouldn't have to be.
Unread 22-02-2011, 09:56
Swampdude's Avatar
AKA: Dan Quiggle
Rookie Year: 1999
Has that rule been clarified? I haven't had time to look, but I could read that different ways. Seems they should put a time frame on that rule. It's stowed right at the height limit anyway.
www.179swampthing.org
Unread 22-02-2011, 10:56
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Also, this green is slightly darker than previous robots
Unread 22-02-2011, 13:22
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
With respect to the deployment height, it's during deployment. Deployment starts as soon as the Minibot crosses the cylinder formed by the vertical projection of the base of the tower.
If you're stowed right at the height limit, something you should check is that the Minibot doesn't go over the line while being deployed. The line is to be treated as a plane, according to the GDC via Q&A. It doesn't look like you'll have much of a problem there, but it never hurts to check.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 22-02-2011, 13:32
Swampdude's Avatar
AKA: Dan Quiggle
Rookie Year: 1999
Thanks, that makes more sense.
Unread 22-02-2011, 13:37
Bjenks548's Avatar
AKA: Brendan
Reread G<22>
<G22> HOSTBOTS may not contact their ALLIANCE‟S MINIBOT while any part of it is above the DEPLOYMENT LINE. Violation: TOWER is disabled
I don't see anything their about this being only during deployment. It is just in the End Game section of the manual.
END GAME – the final 10 seconds of a MATCH.
If I am wrong please can you link me to the Q&A that disproves me
Unread 22-02-2011, 13:55
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
It's in the end game section; you can only deploy during the end game. Think about it. Admittedly, you could apply it anywhere else on the field; it's just much harder to enforce away from the towers.
There are a couple of related Q&As, though they're on <G21>.
http://forums.usfirst.org/showthread.php?t=16251
http://forums.usfirst.org/showthread.php?t=16981
The second one does say that <G21> and <G22> work in combination.
Past teams:
Unread 22-02-2011, 14:05
Bjenks548's Avatar
AKA: Brendan
That really stinks for the teams without a mini bot that are in the scoring zone with a tube when the end game starts... The best example I can think of with regards to not having the minibot above that line at any point is 148. If <G22> wasn't there, their minibot could have been at the end of the drop down bridge. As long as they dropped it before they crossed over the tower base. Instead of them running the minibot forward off the bridge once its droped. (sorry swampthing this probably isn't the place for this discussion and anyway your deployment is perfectly legal)
Unread 22-02-2011, 14:09
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
What do you mean? If you don't have a minibot aboard, you can't contact one above the deployment line. At least, it's much, much harder.
Edit: I think I see what you mean now. You're thinking, based on my post, that the only thing you can do during the end game is deploy. This was thought before TU#5 came out, too; my apologies for using the older type of wording. I should have said that the only time deployment was legal was during the end game.
Past teams:
  #15   Spotlight this post!
Unread 22-02-2011, 15:32
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
I like the simplicity of this year's bot 179.
It reminds me greatly of your 2005 beast not necessarily on the physical design, but on the design strategy. The minibot looks great too.
-Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
