Go to Post Totally agree on the fact that legal strategies are... legal. - Kevin Sevcik [more]
Unread 22-02-2011, 09:41
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
Rookie Year: 2010
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
limit switch problem
After 16 hour of working on two limit switches, they still won't work. I wrote a code for our limit switches that when our top limitswitch is pressed it would stop the motor from going up so the motor can only go down, and when the bottom one is pressed it stops the motor from going down so the motor can only go up. The problem is that I does not do any of that. Can any one please review this code an tell me where I went wrong?
Code:
		    if (ds->GetDigitalIn(3) != 1 || ds->GetDigitalIn(3) != 1 && Carriage_down->Get() == 0)
			    Carriage_motor->Set(1.0);
			    while(Carriage_down->Get() == 0)
			    	Carriage_motor->Set(0.0);
		    else if(ds->GetDigitalIn(4) != 1 || ds->GetDigitalIn(4) != 1 && Carriage_up->Get() == 0)
		    	Carriage_motor->Set(-1.0);
			    while(Carriage_up->Get() == 0)
		    else
Unread 22-02-2011, 13:55
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: limit switch problem
Originally Posted by Straberrie View Post
From what I understand, you just want your motor to stop if it reaches any of the above. Your code seems a little too complex for something that should really only be a few lines.
If the motor is forced to stop whenever a limit switch is pressed, it will stick at the end of its travel and never be able to leave.
One easy way to do it "right" is to use the "top limit" switch to turn off the motor only if it's being commanded up, and use the "bottom limit" switch to turn off the motor only if it's being commanded down.
Code:
  // use operator console buttons to decide which way to run the motor
  if (ds->GetDigitalIn(3) != 1)
    motorvalue = 1;
  else if (ds->GetDigitalIn(4) != 1)
    motorvalue = -1;
  else
    motorvalue = 0;
  // stop motor from being commanded forward if at lower limit
  if (Carriage_down->Get() == 0 &&  motorvalue > 0)
    motorvalue = 0;
  // stop motor from being commanded backward if at upper limit
  if (Carriage_up->Get() == 0 && motorvalue < 0)
    motorvalue = 0;
  Carriage_motor->Set(motorvalue);
Unread 22-02-2011, 14:04
Straberrie's Avatar
Straberrie Straberrie is offline
The Plague
AKA: Rebecca
FRC #0375 (Robotic Plague)
Rookie Year: 2007
Straberrie will become famous soon enough
Code:
    motorvalue = 1;
    motorvalue = -1;
  else
    motorvalue = 0;
    motorvalue = 0;
    motorvalue = 0;
I deleted my post, it was wrong, thank you for correction! =D
Team 375: The Robotic Plague
Current Robot: I-Chihuahua
Last Event: Big Apple Breakaway
