Go to Post One of our electrical engineers would bring his kids in every so often, so they could actually see their dad during build season. - Karthik [more]
Unread 22-02-2011, 11:16
pr0ph3t pr0ph3t is offline
Programming and Controls Mentor
AKA: Jeff Ousley
FRC #3528 (Up Next)
Team Role: Coach
Rookie Year: 2011
pr0ph3t is an unknown quantity at this point
battery voltage monitoring
We have our analog breakout connected to the 9201 in the first slot of the cRIO. We have 12 volts from the PD board connected to the wago connector in J3 on the analog breakout. We have a jumper installed on the outer two pins of J4. Is it necessary to connect 12 volts from the PD board into Ain8 on the J2 block for monitoring to work properly? The reason I ask is I saw another team's robot where they had done this. I couldn't find reference to it in any document including the Typical Application section in this doc:
http://www.usfirst.org/uploadedFiles...reakout(1).pdf
