no image from camera.
i am using a heavily modified version of the default code and i dont seem to be getting an image from the camera. i have not changed anything having to do with the camera and i have no image. it is plugged into ether slot 2 in the crio and the power is on. green light around the lense.
thanks in advance -Wyatt C FIRST Team 1307 |
Re: no image from camera.
Did you set up the camera, add the FRC account with FRC password?
Greg McKaskle |
do you have communication with the robot?
Only certain ethernet cords work with the camera. Check to see if the light is on in the ethernet port the camera is plugged into, if it is then it is programming. If the light isn't on then try another cord preferably the one that came with the camera. We faced a problem like this when we used a different ethernet cord.
i followed the NI tutorial exactly. however still no image from the driver station.
do i have to build or deploy the driver station project? also when it made the new project for driver station it named it 2010 could that cause an issue |
