mechnical arm question
hi,
we use 2 cim motor, a toughbox and sprockets to move our arm (single joint). its moving fast but if we let go of the joystick it falls down (it doesnt hold itself up). what can we do (mechanicly\electronically) to solve this? thanks |
Re: mechnical arm question
Counterweight past the pivot or surgical tubing/bungee cords as an assist.
(or any other method . . gas shocks, springs, whatnot) |
or gas springs...
I saw the title of this thread, and before I clicked on it I thought to myself: "I bet the answer to the question is -- add surgical tubing."
Yep. Add surgical tubing, neutrally balance the arm. http://blog.iamjvn.com/2011/02/jvn-b...m-loading.html -John |
How did you program it? Do you have feedback control running?
My worry: my team does not have a counterbalance or anything, just a closed loop. Now we never tested out the physical arm so... My worry is that the motor or speed controllers are going to burn out.
@davidthefat
Well, if you're worried about it, I'm sure plenty of people around here would be happy to help you figure out if you need passive assistance (to borrow a phrase from JVN) or not. But we'd need information like the motors powering it, the gear ratio, the approximate center of gravity and weight, etc. before we could help with that. |
Now I don't trust WPI's PID loop (sorry guys) so I'll be writing my own from scratch |
we are using a counterwieght.
we dont have feedback control running, how would that work ? currently we control it buy pushing\pulling the joystick making the cim (through a jaguar) turn the arm up or down, but when its up and we let go it falls down again. in what manner will surgical tubing help? picture anyone? |
#10
Neutral balancing with some kind of elastic potential energy device will help (assuming the geometry is right). Futhermore, setting your speed controller to 'brake' instead of 'coast' will help further.
#11
I'm not sure about the other languages, but with LabView the PID Control functions are developed by National Instruments, not WPI.
#12
The C++ code uses WPI's libraries. From what I've seen it's good enough, but for more accuracy, you should create your own PID loop.
#13
I'd like to contribute here with a few pictures and details to give an example of what I feel is a very well executed arm. (I really don't mean to be bragging, I just know it works really well.)
Let me start with: KOP FP motor and transmission and an additional 4.125 chain reduction for a total reduction of ~495:1. With the efficiency of the stages added in we have a useful power reduction of 495*.59 = 292.5:1. (BTW, the floating chain tensioner has been replaced with a fixed one, as seen in the second picture.) ![]() The surgical tubing was added to assist the motor. It balances the arm, when the arm is retracted, at about 120 deg. When the arm is extended, it balances at about 60 deg. This arm can easily swing 270 degrees in 4 seconds. The thing to understand is this speed is with use limiting the drive to the FP motor to only +/-35%. We are using a PID control for both positioning and to holding the arm. Honestly, even if we remove power, the arm holds it's position. ![]() The best part is, this motor barely, if ever, rises above room temperature. |
