Motor in Autonomous.
Created robot project without game code. Teleop works fine. When I add motors in autonomous they don't run, but the robot will drive. Please help.
Thanx, David ![]() |
Re: Motor in Autonomous.
I think you need shift registers instead of loop tunnels try that and tell me if it works.
Okay. I'll try that. I had tried that on this code before with what I have coded disabled. Does it need to be deleted?
Thanx David |
Im not sure what your asking there
Here are some "issues", although none of these I don't think are the cause of your problem:
-You should not need shift registers. It is still passing the same reference. -The +1 in your while loops isn't needed, i is incremented automatically. (unless you want your while loop to run 1 less than the indicated number. -I would reduce the timer value to less than 50 mS, like 40 or 20. There isn't really any reason to run it longer. -We like using the express vi "Elapsed Time" instead of looking at the the i value. It is easier to program and I think it's more consistent. But I think your issue is either in your references (check the Begin and make sure they match) and check if it works in Teleop. If it works in Teleop it is a Programming issue, if not then Electrical. Last edited by DavidGitz : 22-02-2011 at 22:43. Reason: clarification |
Thanks everyone. Got it to do something with arms and drive motors yesterday (a little more on the drive motors then I wanted
). So I guess I'll code it now and test it at regionals. Thanx again, David |
