Go to Post It's always FIRST season. - Foss@Team176 [more]
Unread 02-22-2011, 08:21 PM
Bethie42's Avatar
Bethie42 Bethie42 is offline
AKA: Bethany Carlson
FRC #0956 (Eagle Cybertechnology)
Bethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to behold
Limit switches in autonomous
Our limit switches [to regulate Jaguar-implemented 'elevator' for arm] are working fine in teleop but not in autonomous. I've tried putting a print to driver station in the limit-switch statement in autonomous, and it never prints:
Code:
// test if limit switch works: it doesn't.
	  if (topElevatorLimitSwitch->Get() == false){
	  elevatorJaguar->Set(0.0);
	 driverStationLCD->Printf(DriverStationLCD::kUser_Line5, 1, "Elevator stopped");
	driverStationLCD->UpdateLCD();
	else {
	     elevatorJaguar->Set(1.0); // Run elevator up
	    driverStationLCD->Printf(DriverStationLCD::kUser_Line5, 1, "Elevator up");
I tried running just that bit during autonomous, and it never runs: the motor does nothing, the lights indicate it's not running, and the driver station never displays either printf.
Here's the full autonomous code:
Code:
LencVal = lEncoder->Get();
		RencVal = rEncoder->Get();
		//it turns out, the input must be less than ~21 characters.  Anything longer won't be displayed
		driverStationLCD->Printf(DriverStationLCD::kUser_Line4, 1, "Lenc cnt:%d         ", LencVal);
		driverStationLCD->Printf(DriverStationLCD::kUser_Line5, 1, "Renc cnt:%d         ", RencVal);
		//compressor control
		int compressorValue = pneumaticLimitSwitch->Get();
		if (compressorValue == 1) {
			compressorRelay->Set(Relay::kOff);  // If relay is true (120 PSI) turn off compressor
		else {
			compressorRelay->Set(Relay::kOn);
		leftValue = lLineTracker->Get();	// read the line tracking sensors
		middleValue = mLineTracker->Get();
		rightValue = rLineTracker->Get();
if ( (LencVal < 7300 )){  // overshoots: goal encoder count is 7390
			robotDrive->TankDrive(-0.25, 0.25);
			driverStationLCD->Printf(DriverStationLCD::kUser_Line2, 1, "Still driving");
			else {
		else {
			robotDrive->TankDrive(0.0, 0.0);
			gripperSol->Set(true); // If we're at the T, let's score
			driverStationLCD->Printf(DriverStationLCD::kUser_Line2, 1, "At T");
The Jaguar happily obeys the commands to stop when the encoder value is reached.
Teleop limit switch stuff works perfectly.
Code:
		else {
		// move the elevator up, as long as the limit switch hasn't been pressed
		if ((elevatorJS->GetY() < 0.0) && (topElevatorLimitSwitch->Get() == true)) { // false means pressed...
			elevatorJaguar->Set(elevatorJS->GetY());
		// move the elevator down, as long as the limit switch hasn't been pressed
		else if (elevatorJS->GetY() > 0.0 && bottomElevatorLimitSwitch->Get() == true){
		// in all other cases, turn motor off
		else {
		// y = x linear relationship
		//robotDrive->TankDrive(rJS->GetY(),-lJS->GetY()); // inverted with - to circumvent non-con wiring
		// Joystick sensitivity adjustment: y = .6x^3 + .4x, leftJS negative (see above)
		//driverStationLCD->Printf(DriverStationLCD::kUser_Line2, 1, "L:%f         ", lJS->GetY());
		//driverStationLCD->Printf(DriverStationLCD::kUser_Line3, 1, "R:%f         ", rJS->GetY());
		//driverStationLCD->UpdateLCD();
		robotDrive->TankDrive(((.6*(rJS->GetY())*(rJS->GetY())*(rJS->GetY())) + (.4*(rJS->GetY()))), -((.6*(lJS->GetY())*(lJS->GetY())*(lJS->GetY())) + (.4*(lJS->GetY()))));
		//motor for elevator : this works, after the the Great Jaguar Fiasco of 02-18
		//elevatorJaguar->Set(elevatorJS->GetY());  // Assigns elevatorJS to control Jag
		//solenoid control
	    //Raise and lower arm
		if(driverStation->GetDigitalIn(2) == true) {
			elbowSol->Set(true);     // raise and lower 'elbow'
			//driverStationLCD->Printf(DriverStationLCD::kUser_Line4, 1, "Elbow sol raised");
		else {
			elbowSol->Set(false);
		// Open and close gripper
		if(driverStation->GetDigitalIn(3) == true) {
			//driverStationLCD->Printf(DriverStationLCD::kUser_Line5, 1, "Gripper sol closed");
		else {
			gripperSol->Set(false);
		// Release pneumatic latch to deploy minibot
		if (driverStation->GetDigitalIn(4) == true){
			deploymentSol->Set(true);
			//driverStationLCD->Printf(DriverStationLCD::kUser_Line6, 1, "Deployment latch triggered");
		else {
			deploymentSol->Set(false);
		    	// appears to work [02-19 jaguar problem] copied from 02-17 code
		       if (elevatorJS->GetRawButton(3)== true && outDeploymentLimitSwitch->Get() == true){
		       		deploymentJaguar->Set(1.0);  // Run motor out/forward
		       else if (elevatorJS->GetRawButton(2)== true && inDeploymentLimitSwitch->Get() == true){
		    	   deploymentJaguar->Set(-1.0); //Run motor in/backwards
		       else{
		    	   deploymentJaguar->Set(0.0); // Don't run motor
Any thoughts? Thanks!
Robot is now a verb.
We're back to square one...while we're at it, let's redesign square one!
Team 956: Celebrating ten years of FIRST!
Code:
Team record 2002-2011
2002: Highest Rookie Seed, AOR
2003, 2006, 2012: Xerox Creativity Award, AOR
2006: Semi-finalist, Sacramento Regional
2009: Quarter-finalist, AOR
2010: Quarter-finalist, AOR
2011: Semi-finalist, AOR, and Dean's List finalist, AOR
Personal record:
2008: Lead scout
2009: Lead scout, publicity
2010: Lead scout, publicity, fundraising, Chairman's, videography
2011: Team captain, lead programmer, fundraising, Chairman's, publicity, wrench-turning, Dean's List finalist at Autodesk Oregon Regional
