Go to Post the usual Canadian thing - Karthik [more]
View Poll Results: Will we see a sub 1 sec mini bot?
Yes 93 41.89%
No 129 58.11%
Voters: 222. You may not vote on this poll
Unread 22-02-2011, 21:44
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
Team Role: Coach
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
Under 1 sec mini bot
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 22-02-2011, 21:58
MarcD79's Avatar
MarcD79 MarcD79 is offline
AKA: Marc
FRC #0176 (Aces High 176)
MarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond repute
Re: Under 1 sec mini bot
At Suffield Shakedown, team 175 deployed in about 8-10 seconds. I was told by a referee that a robot has 10 seconds to climb & activate the tower. If it deployes at the 1 second mark, it still has 10 seconds to climb & activate. There is a 10 second delay built into the system to accommodate this.
Mentor & Volunteer
Field setup, Field Supervisor & disassemble Suffield Shakedown 2003- present (2015)
Connecticut Regional Field setup, disassemble & FTAA 2009, 2010, 2011, 2012, 2013 (Field reset & Assistant Field Supervisor), Field Reset Pine Tree Regional 2013, Field Supervisor, setup & take-down at Groton & Southington Districts 2014, Field Reset Hartford District 2014. Field Reset Boston District Championship 2014. FLL Judge Fall 2014
Field Supervisor/Set-up & Take-down Waterbury & Springfield , Field Reset/Set-up & take-down Hartford N/E District 2015. Field Reset NE Champs 2015. FLL Judge Fall 2015.
Suffield Shakedown 2016, Field Super 2016 Stronghold Waterbury.
Unread 22-02-2011, 22:03
Chris is me's Avatar
AKA: Pinecone
I think the OP was referring to a minibot that climbs in under one second.
I think one second is a hard maximum.
Unread 22-02-2011, 22:07
Joe G.'s Avatar
Joe G. Joe G. is online now
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
1 second minibot? Maybe
1 second deploy+climb? Not a chance.
I'm of the opinion that the minibot race will be won and lost by the deployment system, much more than the minibot itself.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 22-02-2011, 22:09
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Rookie Year: 2007
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
I would have to agree with you.
Unread 22-02-2011, 22:19
AKA: Pinecone
I disagree. Time of "deployment" doesn't really matter in the sense most people are thinking. You can extend your robot to the end of your arm or platform before the 10 seconds, as long as you're away from the base of the tower. At 10.00, you just drive into the tower with your already extended minibot and call it a day. Deployment time doesn't really come into play there.
Unread 22-02-2011, 22:27
Cyberphil's Avatar
That Guy
AKA: Phil
Rookie Year: 2007
Wait, run that by me one more time.
If I am hearing you right, you believe deployment time will be almost instant if it is already extended before the 10 seconds. Then Right at the 10 second mark the robot drives the minibot to the pole, then the minibot climbs up the pole.
Is this correct?
Unread 22-02-2011, 22:58
Ted Weisse's Avatar
Ted Weisse Ted Weisse is offline
AKA: xMentor/Inspector/Referee
Ted Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of light
As per section 1 of the Game Manual:
"DEPLOYMENT starts when the MINIBOT breaks the vertical projection of the TOWER BASE circumference."
So even if the minibot was extended prior to the end game as soon as it crosses the vertical projection of the Tower Base circumference it is said to be in deployment.
If I am not for myself, who will be for me?
If I am not for others, what am I?
And if not now, when?
-Rabbi Hillel
Jewish scholar & theologian (30 BC - 9 AD)
Unread 22-02-2011, 23:00
AKA: Pinecone
Is this correct?
Yes.
For all I care, deployment could take a minute and a half. It's net effect on the minibot race time would be zero if the deployment mechanism is designed such that an extended minibot could just be driven over the base and onto the pole at the 10 second mark.
Unread 22-02-2011, 23:09
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Regardless of what your mechanism is, you cannot put the minibot within the base perimeter projection until 10 seconds hits. Therefore, the "Deployment time" as being discussed here is equivalent to the discrete amount of time for DEPLOYMENT as defined in the manual: the time it takes from when your minibot breaks that projection, to when it starts to climb the pole and leaves contact with the hostbot. This is a non-trivial amount of time if you are talking about the total time it takes from the 10 second mark to when the tower is triggered.
If you have a minibot which can climb the pole in 1 second, but it takes 0.5 seconds for the hostbot to get the minibot from the edge of the tower base to the pole, you still don't hit that tower until 8.5 seconds left in the match at best. You can have all sorts of mechanisms that extend and latch or do whatever to prepare for the endgame before 10 seconds, but no one's minibot is going to get around the time it takes to travel those 15 inches to the pole from the edge of the tower base. If you have a super fast minibot, you best have a super fast way to get it to the pole or you won't beat the slightly slower minibot with the faster deployment.
Will we see minibots that take a second or less to get to the top of the pole? Maybe. Will we see minibots that trigger their tower before 9 seconds left in the match? Very very slim to impossible.
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
If that's your plan, be ready for the opponent robots to absolutely crush you at 12 seconds. One little push and you lose your alignment. I have a feeling that any good deployment system will need to have error correction built in to be effective at competition.
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 22-02-2011, 23:19
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
Not if you are nested in your lane.
Unread 22-02-2011, 23:20
WizenedEE's Avatar
WizenedEE WizenedEE is offline
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Team Role: Leadership
Rookie Year: 2010
WizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to all
Driving into the tower can still take time. Lining up is also an issue.
Our team can deploy in a little less than .7 seconds, and also has some things to line the robot up so it will hit every time. Our minibot is currently a little less than 3 seconds (I think) but they're building a custom chassis so it'll speed up at least a little bot (pun intended). We're using magnets to hold on.
And to the thread title, no, I don't think we'll see a sub 1 second minibot, never mind the deployer. Seriously, 10 fps?
Unread 22-02-2011, 23:33
liam.larkin's Avatar
liam.larkin liam.larkin is offline
We will find a way or make one!!
FRC #0272 (Cyber Crusaders)
Rookie Year: 1998
liam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to behold
A one second Deploy and Climb.......If it happens I shall bow down before that team and grovel and ask how they tolerate us mear mortals.....
But seriously. I think a whole bunch of teams have built minibots that climb in the sub 2.5-2.75 range. We even seen evidence of a few that are at just around a second.
The key as many of you have pointed out is the deployment time and/or method. It is quite difficult in the heat of the game to hit a 1 3/4 OD pipe from about what 40 ft. I have seen some teams with some manual line up devices that seem to work really well. I am also sure some teams ours included will use sensors and some nice programming to take the human factor out and let the robot line itself up manually. We will see I am very intrested to see who can show us on a consistent basis their ability to deploy and climb each round.
I trully believe if you can deploy/climb accuratly each round and even if it takes say 7 seconds you will be quite attractive at least for the first few weeks. But I guess we will all see sooner then later.
  #15   Spotlight this post!
Unread 22-02-2011, 23:36
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
Now, how does a team manage to get around 1-2 seconds? We all have the same motors... Or do they not use motors at all?
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
