Go to Post Build a student a robot and it will keep him/her busy for a few days in the spring. Teach a student how to build(design, wire, program) a robot and they will stay away from home, use some really strange language and wear funny clothes the whole year long. - Al Skierkiewicz [more]
Unread 23-02-2011, 10:27
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
Why FIRST is different
I decided to start this thread separate from a lot of the debate going on in the “Mentors on drive team” thread to emphasize a couple of points, from my view. It's been discussed before but is still a hot topic.
If your robot is “student designed, student built”, I’m sure you learned quite a lot. No doubt trial and error is where you gain a lot of knowledge – “Good judgment comes from experience, experience comes from bad judgment”. But that is not engineering. Engineering is understanding the principles involved and developing an optimal solution before you build it, analyzing it prudently, and then building and testing to make sure your assumptions were correct. It is an iterative solution as well, but the iterations require analysis of the results (failures) to correct your “model” of the system and then reviewing the modifications to be made against the appropriate design criteria (cost, weight, time, strength, deflection, etc.) to see that you have adequate margins before you build another one.
If you, as a student, believe that you can design and build a robot as well as a group of engineers, why would that inspire you to go to engineering school? If you didn’t need any “engineering training” to do it, why would you need engineering training at all? Maybe it’s because you didn’t get a chance to see your robot being engineered. Can you calculate the tooth stresses on your gears and see how much load they can take? If you move the load path on your arm 4 inches, how much will the deflection change? If you change that beam from tubing to channel, what happens to the torsional stiffness? If you change from a roller bearing to a needle bearing, can you take the thrust load? How fast will the actuator deploy if you use this solenoid versus that one, or two of them? You could certainly learn all those things by trial and error, but in the real world you don’t get an unlimited budget, and if you’re building a new $500 million dollar plane you’d rather not crash 7 or 8 prototypes figuring things out. If your stuff never breaks, how much is it overdesigned? Do you have a safety factor of 10 when 1.5 will do? In the real world that costs weight (critical in aviation) and money, so overdesigned is not better.
As Dave Lavery said at kickoff a few years back, there are hundreds of competitions and activities and science fairs where it’s all about the students doing it themselves and learning from that experience. FIRST is the one that is different. It is about students working with engineers and learning what engineers do. If you see a pit where it’s just engineers working on the robot, they’ve missed the point as well. The successful teams understand the partnership.
Close enough to taste it, too far to reach it
