Interpertation on Bumpers: Do the bumpers need to display the team numbers?
We have some old plexiglass that has our team number on it and we were going to mount that on the robot. Do we also need to put the team number on the bumpers?
I was curious since on the 2011 FRC inspection checklist for Logomotion mentions: "Team number displayed with 4" tall x 3/4" stroke, on the bumpers, 4 locations at approximately 90 deg spacing, in contrasting color or background." Thank you ![]() |
Re: Interpertation on Bumpers: Do the bumpers need to display the team numbers?
Yes, it needs to be on your bumpers, both the red and blue.
And for the contrasting color, as a scout/scouting mentor, I strongly recommend something in the white/silver/bright yellow range. Black lettering looks fine close up, but it's nearly unreadable in the stands.
If you do use black letters, at least put a thin white outline around them. |
Is it really plexiglass or lexan? I wouldn't recommend using plexiglass on a robot: it will shatter upon impact. |
It is plexiglass and we still need to cut it.
Why are you creating room for interpretation when there isn't any?
Jane |
Plexiglass, AKA acrylic, shatters on impact. I've seen it happen, back in 2005 (and the robot that did the shattering drove up a steep angle to do it). That's why it's not recommended in any areas on the robot where it might get hit.
You may be thinking of polycarbonate, AKA Lexan, which doesn't shatter nearly as easily. |
Well, the plexiglass will be located about 2-4ft off the ground. It will be connected the Arm frame which Doesn't hit something on impact >..<
#10
There is no safe place on a FRC robot. |
#11
Yep. That acrylic I mentioned earlier--the impact was at about 3.5-4 feet up. The "ramp" that was gone up could slow or stop a robot pretty well-- except that one. The other 3 sides of the tower shielding (running between arm supports) were Lexan and survived the rest of the season, as did the replacement Lexan panel.
#12
The best place for acrylic is the trash can. There is never a situation on your robot where it would be a better choice than polycarbonate.
#13
This isn't an interpretation. It's a reading of the rule:
For the past, what, 3 years now, we have used plexi for the electrical box, becouse it doesn't bend under load. Never had a problem. Asides from that, true, lexan is much more resilient under shock.
#15
No team I have ever mentored has ever had Plexiglass on their robot. To the original poster: If the rules don't persuade you, note this quote from this document: Quote:
Regards, Mike |
