Go to Post Is Atlanta an Indian word for "take the longest path between two places"? - Klondike Mike [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 21-04-2011, 19:03
Happy Birthday! davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
Re: How many lines of code do you have total?
Originally Posted by PatJameson View Post
What are you going to try to do to have the need to squeeze out more juice, if I may ask?
Also, our's is 1353 lines long at the moment.
Image processing. We aren't sending any feed to the classmate. All the image processing will probably be done on an off board processor. That is where I will utilize the assembly, especially with object recognition.
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 21-04-2011, 21:47
PatJameson PatJameson is offline
FRC #0011 (MORT)
Rookie Year: 2011
PatJameson is on a distinguished road
Interesting. I created a bit of recognition using only java run on a netbook which could send information to the cRIO. We didn't use it this year as there were much less complex ways to complete autonomous, though. The netbook had plenty of processing power for what I did with it.
Unread 22-04-2011, 21:04
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
Eh, not a fan of Java. But thanks for sharing. I have more ambitious goals I guess.
Unread 24-02-2011, 21:15
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Our 2010 robot had about ~3500 lines of code spread across ~20 Java source files. It's interesting to note that the files SwerveModule.java and Config.java each had a total of 228 lines, the same as our team number.
This season is still a work in progress, but when it's all done I'd expect only around half of that.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
