Go to Post [how to read the rules] Slowly, carefully, word by word, taking your time as if it was the last corndog of the summer. - Foster [more]
Unread 26-02-2011, 02:14
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
Window Motors Becoming Hot/Warm
Now that can't be a good sign: I am no electrical engineer, but when a motor gets hot, that is not a good thing. What could be the possible source of this? Now they seem to be hooked on all right, but one gets hot while the other one stays cold to the touch. Something must be short circuited. And while I was testing the motors today, I saw sparks jump out from the corner of my eye (I was staring at the computer screen, so I do not know the cause of the spark) It is not software that is giving it a problem, I am giving them the same voltage. Would it be the Black Jaguars? Only the black jaguar one seems to heat up, that was the case for the other motor that burnt out. Seems like the most obvious, but I would assume the newer ones were more "stable" than the beige jaguars.
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
