Go to Post I didn't get inspired watching my peers and I, I was inspired watching professionals. - AdamHeard [more]
Unread 01-03-2011, 11:49
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
Mentor / Bayou & CMP Division LRI
FRC #0456 (Siege Robotics)
ChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond repute
Re: most "epic" motor ever
[quote=JesseK;1033040]Eh, I'd like some sort of constraint on CIMs.../QUOTE]
How about weight? Each 2.5" CIM weighs aout 2.5 lbs IIRC. 4 = 10lbs, 8 = 20 lbs. Unless someone knows some magic I don't there really isn't any way to lighten them. At some point most teams are going to have to use lighter motors so as not to eat up so much of their 120 lb weight budget. I think allowing 6 CIMs at most would be a reasonable thing to do unless they up the 120 lb weight limit, increase the number of 40A slots on the PD board, and up the 120A main breaker - none of which I see happening anytime soon. There are plenty of contraints already limiting the "unlimited use of CIMS".
Unread 27-02-2011, 23:15
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Originally Posted by ratdude747 View Post
having seen motors from years past, i have seen some beastly ones. like the van door and the minibike cim.
so, What in your is the most epic motor ever included in the KOP?
Those were poseurs.
The van door motors were good in that they were the largest worm geared motors available, but they were only around 70 W output. And when it came down to using the worm gear for holding something in place, you quickly discovered that they could be backdriven one of two ways: either because the plastic worm gear's efficiency was too high, or because you'd stripped the teeth off of that aforementioned plastic gear.
Similarly, the minibike motors (CIM FP801-005/Fisher-Price) were only about 270 W. Regular (smaller) CIMs are more powerful.
My vote is for the Bosch drill motors in the kits in 2003 and 2004 (Bosch 2 607 022 078/Scintilla). Their output was 448 W, with a free speed of 19 760 rev/min. If it weren't for the tricky mounting points, the 0.7 module gear and the fragile and exposed electrical connections, they'd be perfect....
In fact, the only other motors to approach that kind of performance were the incredible self-destructing Fisher-Prices from 2005 (the Mabuchi 74550-0642, which was designed for 6 V, but given to us to run at 12 V with 407 W output power).
Unread 27-02-2011, 23:42
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Well, if you were looking for beastly, it looks like that was answered above.
However, I really miss the keyag motors. I don't know much about their power outuput, but it was definitely more than the densos we have now. Also, globes were great! You could use them for just about any sort of manipulator.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 27-02-2011, 23:58
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
I know everyone hates them but I really like denso window motors when used correctly. Non-backdriving and low rpm thanks to the integrated worm gear drive.
Everything else, FP and CIM.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 28-02-2011, 06:46
DinerKid's Avatar
DinerKid DinerKid is offline
AKA: Zac
FRC #1768 (Nashoba Robotics)
DinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of light
Totally agree. they are definitely one of my favorites. I really like that the Denso gives you an output speed that you can easily work with, there are no massive reductions to deal with in most cases.
My team has a bit of Tim Taylor in them so "just put a CIM on it" can be heard just about every day.
~DK
Unread 28-02-2011, 07:23
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
Team Role: Mechanical
Rookie Year: 2007
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
My favorite motor was the fifth CIM we got in 2010. It added a really cool twist to the game.
Unread 28-02-2011, 09:19
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
I'm really liking the RS775-18 thus far. Seems plenty powerful, takes to stalling pretty well (better than an FP) and if it weren't for the transmissions being nearly impossible to get, I'd say they are the best motor in the KOP this year.
One year it'd be nice if FIRST gave us a list of Motors we could use with the only restriction on quantity being a total maximum power output. (Sum of all motor power can't exceed 2000W or something.) That'd be interesting.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 28-02-2011, 09:34
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Or they could say "Each motor must have exactly 1 breaker, have fun".
*You can't have gigantic motors because the max. current per motor is limited by the 40a breakers
*You can't have too many large motors because you only have 8 40a breakers
*You can't have a ridiculous number of motors with 30a or 20a breakers, because you only have so many 30a slots as well, and a few things also use those breakers (like the cRio modules).
Favorite motors:
CIM motors are awesome for high-power things like drivetrains.
FP or 550 motors are awesome for high power but more predictably-loaded things (such as arms) or high power, light weight things (like roller claws or other high-up mechanisms)
An AMP or CIM-U-LATOR makes the FP or 550 think it's a CIM.
I would be very happy to just have those two motors. Most things would use a CIM interface, and the limited number of CIMs could be distributed, and the rest could get FP or 550's through CIM-U-LATORs. Anything without a CIM interface would accept a FP or 550 directly.
Kettering Motorsports
Unread 01-03-2011, 06:59
ratdude747's Avatar
ratdude747 ratdude747 is offline
Official Scorekeeper
AKA: Larry Bolan
ratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond repute
Favorite motors:
to your team, anything that can be mounted to a dewalt tranny is fair game
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010, 2783 Engineers of Tomorrow 2011, Event Volunteer 2012-current
DISCLAIMER: Any opinions/comments posted are solely my personal opinion and does not reflect the views/opinions of FIRST, IndianaFIRST, or any other organization.
Unread 28-02-2011, 00:00
Duncan Macdonald's Avatar
Duncan Macdonald Duncan Macdonald is offline
Globe Motor Fan Club
FRC #0610 (Crescent Robotics)
Duncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond repute
Send a message via MSN to Duncan Macdonald
Never had an issue with a CIM or globe. Stripped, deformed, burned out, thermal tripped, or broke the leads on nearly everything else.
Queen's Applied Science '13, Applied Mathematics
Unread 28-02-2011, 00:04
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
What he said, although we have managed to push CIM's to the frying point before (4 wheel long-config skid drive. The nightmares of watching it try to turn....)
Attending: MN Duluth Regional
Unread 28-02-2011, 01:20
Andy A. Andy A. is offline
Getting old
FRC #0095
Team Role: Coach
Andy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond repute
Originally Posted by Tristan Lall View Post
Those were poseurs.
That was a fun year. We didn't figure out the design voltage difference until we were already committed to using two of them in an xrp transmission. It was fun finding out they were 4 times more powerful then we had anticipated.
It's a miracle we didn't kill them, or the transmission.
Unread 06-03-2011, 02:14
11douglash 11douglash is offline
FRC #1072
11douglash is infamous around these parts11douglash is infamous around these parts
Vandoor Motor, hands down.
Yes, it's old. Last included in 08 kit. But by god, there's a reason that we joke that is has more torque than a toyota camery in the camery's highest gear.
Unread 06-03-2011, 08:53
galewind's Avatar
galewind galewind is offline
... more like a temperate breeze
AKA: Chris Gregory
FRC #1089 (Team Mercury)
Team Role: Teacher
galewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond repute
Send a message via AIM to galewind
I'm going to have to say that size to punch, I am REALLY REALLY liking the BaneBots rs775-18 motors. They're just darn cool motors, and they're a lot more versatile than people think. Just make sure your power leads aren't grounded to the case.
Chris G
Advisor, Team Mercury (1089), Hightstown High School
