Go to Post "Its not a glitch its a new feature, we just dont know how to use it yet" - Cuog [more]
Unread 27-02-2011, 23:38
Team 2524 Team 2524 is offline
FRC #2524
Rookie Year: 2011
Team 2524 is an unknown quantity at this point
Clicking Noise when we switch Robot on
When we switch the robot on, there is a clicking noise and I have no clue if that's good or bad but, I'm assuming the bad.
I think it's the jaguar or the PD but I'm not really sure because it's hard to pinpoint the exact location.
Unread 27-02-2011, 23:41
Steve Kaneb's Avatar
Steve Kaneb Steve Kaneb is offline
I like two Championships, AMA!
AKA: Alex
FRC #0190 (Gompei and the H.E.R.D.)
Steve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really nice
Send a message via AIM to Steve Kaneb
Re: Clicking Noise when we switch Robot on
Most likely a breaker tripping in your Power Distribution board. They make a clicking noise as they trip and reset. You should check which controller is over the breaker's limit, it's likely shorted.
WPI District 2016 Volunteer Coordinator.
2016 Referee: NE Granite State, NE UMASS Dartmouth, NE Rhode Island, NE Boston, NEDCMP
Unread 28-02-2011, 14:09
FRC #2524
Rookie Year: 2011
If its shorted does it mean I have to replace it?
Unread 28-02-2011, 14:14
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
If you suspect a breaker, pull all of them out of the PD. Replace them one at a time until the noise returns. Then you will know what branch is causing a problem. It is a simple matter then to track down the cause.
Please note: Breakers that are tripping due to over current conditions will usually get hot. Check each breaker for high temp before you pull it.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 27-02-2011, 23:45
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
It's probably a snap action circuit breaker on the Power Distribution board. They click when they trip, and again when they reset a few moments later. It's very likely that you have a short circuit somewhere. If your PD is one of the newer style, there will be a red light showing next to the tripped breaker.
If you have the power miswired to the output of a Jaguar instead of the input, you'll end up with a short circuit (and a fried Jaguar).
Unread 27-02-2011, 23:51
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
...or if you have one of *our* black Jaguars, you end up with a short circuit and a fried Jaguar even if it is hooked up correctly! (Lucky for us, it was just the practice 'bot...)
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 27-02-2011, 23:57
lscime lscime is offline
AKA: Luke Scime
FRC #2614 (Mountaineer Area RoboticS (MARS))
lscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to behold
The pneumatic solenoids also make a clicking noise when they trigger without any air.
-Luke
Unread 28-02-2011, 07:40
Pamelot2067's Avatar
Pamelot2067 Pamelot2067 is offline
Keeping The Freshmen In Line
AKA: Pam Perkins
FRC #2067 (Apple Pi Robotics)
Team Role: Scout
Pamelot2067 is an unknown quantity at this point
if the fan in the jaguar is bent they make an annoying clicking sound. it doesnt impare the bot, its just annoying.
APPLE PI ROBOTICS 2067 Guilford, Connecticut
Unread 28-02-2011, 10:05
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
We had the same clicking noise after two of our jaguars went bad. It wasn't the breaker because it was a much higher frequency than one of the snap action breakers and the light on the power distribution board never turned on. I'm not sure of the exact problem but once we replace the jaguar the noise stopped. Make sure that all your Jaguars have a flashing yellow/orange light when you turn your robot on.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
