Go to Post My nagging fear is that I'm a programming dinosaur, stuck in a procedural tar pit and doomed to extinction as the dataflow mammals take over. - Alan Anderson [more]
Unread 28-02-2011, 13:31
salomon90's Avatar
salomon90 salomon90 is offline
AKA: Bryan
None #0005 (GO FIRST)
salomon90 is on a distinguished road
Yet Another Logomotion Score Calculator
You are all probably sick of having all the different score calculators that are out there by now, but yet here is another one for you to consider.
It's based off Silverlight and originally was made for Windows Phone 7 so if anyone has a WP7 you can use the exact same app both on your computer and soon on your phone.
It can score all 4 grids and the minibot race and also has several options for resetting the grids. You can also right click and select to install on your local machine for off web use.
Check it out at z.umn.edu/logomotioncalc. I would love any suggestions, fixes, or improvements.
If you are interested in the source code you can get it at
https://netfiles.umn.edu/users/stadi...omotionWeb.xap
It's a .xap so you need to change the extension to .zip and you can unpackage the code (which is in C#, similar to Java for those unfamiliar).
Happy Logomotioning!
~MN GO FIRST Alumni Organization
-University of Minnesota- Twin Citites
-Electrical Engineering Undergrad
2009 - Team 2526 Crimson Robotics Programming
2010 - Team 2526 Crimson Robotics Electrical / Drive Team
2011 - CARD Team #5 GV Design/ Mechanics
2013 - GO FIRST Director of Research and Development
"Sounds like the future."
Unread 08-03-2011, 00:02
salomon90's Avatar
AKA: Bryan
Re: Yet Another Logomotion Score Calculator
For anyone who is still interested at this point, after watching week one regionals I've updated the algorithms to reflect how the game is actually scored.
Press the autonomous button to toggle autonomous mode scoring for each grid. Also, while you are limited to three ubbers for each alliance, there's a bug that will subtract from your points if you try to exceed the limit and place more ubbers. I'm in the process of fixing this, so if you do use this, please bear with me. Thanks.
*Edit*
That minor bug that I mentioned earlier has been fixed. You now no longer need to worry about accidentally subtracting points from your own grid. Hope some find this helpful.
