Go to Post A challenge to those of you grumbling about the refereeing this year: Be a referee next year. - Alan Anderson [more]
Unread 01-03-2011, 12:00
Team 1574's Avatar
Team 1574 Team 1574 is offline
FRC #1574
Team 1574 is an unknown quantity at this point
MisCar 1574 - 2011 Robot!!!
MisCar 1574 Presents:
~~~~~~~Our 2011 Robot~~~~~~~
http://www.youtube.com/watch?v=oJ0wyg9lp6U
Robot specifications:
Weight: 52.5 Kg (115.7 lb)
Height: 151.2 Cm (59")
Arm length: 135 Cm (53.1")
Top speed: 4 meter per second (14.4 km\h - 8.9 mp\h)
Robot Abilities:
Hanging tubes on all three heights
Picking tubes from the floor
Tilting a tube to a desired angle
Hanging a tube at the autonomous period on all pegs
Reach pre-set heights of arm and gripper with a push of a button
Sub-systems:
Chassis: Six wheel drive including - two omni wheels in front, MisCar's custom high friction wheels and double omni in the back. All the wheels are driven by timing strips in order to reduce weight.
Gripper: Two conveyors motorized seperately in order to collect and tilt tubes in a fast and efficient way
Sensors: 3 line tracking sensors (provided by Rockwell Automation - from the kit) 2 potentiometers to determine arm and gripper heights, 2 encoders to determine the robot's speed and distance and a switch for recognizing whether the robot is holding a tube or not.
Mini-Bot: Climbs the tower in 2-3 seconds and deployed in less than 1 seconds using a servo motor.
Our Website
SEE YOU AT THE COMPETITION!!!
Unread 01-03-2011, 12:41
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: MisCar 1574 - 2011 Robot!!!
Please don't post the same message in multiple forums.
Closing this thread - use the thread in the "Robot Showcase" forum for any discussion.
(since 2004)
