MisCar 1574 - 2011 Robot!!!
MisCar 1574 Presents:
~~~~~~~Our 2011 Robot~~~~~~~ ![]() http://www.youtube.com/watch?v=oJ0wyg9lp6U Robot specifications: Weight: 52.5 Kg (115.7 lb) Height: 151.2 Cm (59") Arm length: 135 Cm (53.1") Top speed: 4 meter per second (14.4 km\h - 8.9 mp\h) Robot Abilities: Hanging tubes on all three heights Picking tubes from the floor Tilting a tube to a desired angle Hanging a tube at the autonomous period on all pegs Reach pre-set heights of arm and gripper with a push of a button Sub-systems: Chassis: Six wheel drive including - two omni wheels in front, MisCar's custom high friction wheels and double omni in the back. All the wheels are driven by timing strips in order to reduce weight. Gripper: Two conveyors motorized seperately in order to collect and tilt tubes in a fast and efficient way Sensors: 3 line tracking sensors (provided by Rockwell Automation - from the kit) 2 potentiometers to determine arm and gripper heights, 2 encoders to determine the robot's speed and distance and a switch for recognizing whether the robot is holding a tube or not. Mini-Bot: Climbs the tower in 2-3 seconds and deployed in less than 1 seconds using a servo motor. Our Website SEE YOU AT THE COMPETITION!!! |
Re: MisCar 1574 - 2011 Robot!!!
nice robot, see you at the israeli regional,
from team #2230 ![]() |
Going to be tough competition this year at the Israeli regional!
Good luck to us all, and see you at the competition |
No comments?
