Go to Post This is a once in a life time event for many of you guys. ENJOY it! - Tom Line [more]
Unread 03-03-2011, 10:15
1789Robotics 1789Robotics is offline
AKA: Kris Gregory
FRC #1789 (Cliff Hangers)
Rookie Year: 2010
1789Robotics is an unknown quantity at this point
Dashboard Help
My team and I are trying to figure out why the battery volts reading in the driverstation isn't working for us. I'm not sure what to do or how to fix it so any help would be really helpful!!
Unread 03-03-2011, 10:44
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Dashboard Help
Without any details of what you do see for battery voltage (is it a constant 0, is it constant some other value, does it wildly fluctuate to incorrect values, etc), anything help we provide is based on speculation.
My speculation is that you missed one of the steps in <R61>.
Unread 03-03-2011, 10:50
AKA: Kris Gregory
Rookie Year: 2010
Re: Dashboard Help
Well its stays at zero wether the robot is enabled or disabled. All it ever reads is zero.
Unread 03-03-2011, 11:14
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Dashboard Help
Is the
  • NI 9201 module installed in Slot 1?
  • Analog Breakout attached to NI 9201 module installed in Slot 1?
  • jumper properly bridging the two farthest pins of the header at the end of the Analog Breakout attached to NI 9201 module installed in Slot 1?
  • white Wago connector of the Analog Breakout attached to NI 9201 module installed in Slot 1 connected to a 20-amp circuit from the Power Distribution board?
  • green LED "D2" on the Analog Breakout lit?
And what revisions of the Driver Station and cRIO image are being displayed on the Driver Station diagnostics screen?
Unread 03-03-2011, 13:21
AKA: Kris Gregory
Rookie Year: 2010
Re: Dashboard Help
We figured out that we had the jumper on backwards. Thanks for the help.
