Go to Post I think we are having that "hard fun" that Woodie Flowers keeps talking about. - OZ_341 [more]
Unread 03-03-2011, 13:13
Chris is me's Avatar
AKA: Pinecone
Minibot Motor Press Fit
I'm trying to press fit "something" to the Tetrix motor with transmission removed. The shaft appears to be 1mm in diameter. What size hole should be drilled / reamed into my part in order to nicely press fit onto the motor shaft?
Unread 03-03-2011, 13:39
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Minibot Motor Press Fit
1.00mm diameter? or something else?
Generally a couple thousandths of an inch interference makes a good press fit. But it depends.
Unread 03-03-2011, 13:52
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
I agree with Jim, .001"-.002" per inch of diameter, so your tolerance is pretty small. What material are you pressing on? The softer it is the more press it can tolerate.
Mark
Brick walls are for other people. - Randy Pausch
Unread 03-03-2011, 13:53
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
1.0mm? Our motor shafts are 2.5mm in diameter... (0.0984 inches)
We were able to press fit a 3/32 inch (0.0938 inch) hole in a 6061 aluminum rod (.25" OD) onto the shaft without difficulty. Just make sure you support the back of the motor where the shaft "nub" is so you don't pop out the other side
Unread 03-03-2011, 14:03
BrianT103's Avatar
BrianT103 BrianT103 is offline
AKA: Brian Taylor a.ka. BT
FRC #0103 (Cybersonics)
BrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud of
Send a message via AIM to BrianT103
Jared is right, it is a 2.5mm shaft. Be careful when you're press fitting something on there, I can think of other ways to accomplish what you're trying to ultimately do. Press-fitting may or may not be your best option
Unread 03-03-2011, 15:33
Brandon Holley's Avatar
Brandon Holley Brandon Holley is online now
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
As the others have said...The shafts are 2.5mm. I always try to use a micrometer to measure the exact diameter of each shaft and ensure they are very close to each other. When you are dealing with smaller pieces and press its important to be as accurate as possible.
-Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 03-03-2011, 16:07
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
I used a #41 drill bit which measures .0960 inch. my calipers measured the motor shaft at .0980 in. we are most likely pressing the same "something" onto the motor.
2016 Central Illinois Winner. Curie Division finalist
Unread 03-03-2011, 16:28
AKA: Pinecone
I just got the 1mm number off of a flawed CAD model. Thanks for the clarification.
Unread 03-03-2011, 16:34
AKA: Pinecone
I can't - the shaft seems too small to affix a setscrew to. Is it not?
Unread 03-03-2011, 16:40
DinerKid's Avatar
DinerKid DinerKid is offline
AKA: Zac
FRC #1768 (Nashoba Robotics)
DinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of light
Instead of going with a set screw you could use a "clamp on" style thing you want to attach to the shaft.
~DK
Unread 03-03-2011, 16:48
AKA: Pinecone
~DK
I didn't know clamps came small enough to rigidly fix onto a 2.5mm shaft...
Unread 03-03-2011, 16:54
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Red loctite can also be used to secure press fits. We have it in a custom gearbox securing a RS775 to a tough box shaft and it has worked great.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 03-03-2011, 17:34
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Rookie Year: 2011
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
If you have Loctite 638, then I would recommend that over Red (271) for press fitting something onto a motor.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 03-03-2011, 17:35
College Mentor
AKA: Trent Borman
I was going to mention that, it is actually made for press fitting two smooth objects together, oddly the local autoparts stores here didn't sell it even though it is often used for bearings in cars. So we settled for red loctite which works in low torque situations (like our lifter)
But similarly, I am not sure 638 is technically allowed on the minibot where-as Loctite designed for thread-locking is.
  #15   Spotlight this post!
Unread 03-03-2011, 18:38
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
I would like to introduce you to a wonderful site of utilities for the shop:
http://www.myvirtualnetwork.com/mklotz/#shop
Many, many programs that calculate whatever you need to do in the shop. Your answer should be found with the FITS program.
Go up one level and you will find a bunch of math programs as well.
I have also noticed that the KOP CAD models from PTC have incorrect diameters on the motor shafts.
-T
